Swaybar / lowering relationship: need some help
Old Dec 27, 2010 | 07:08 PM
T4RUSAF's Avatar
Afternoon peeps,
Hello! just picked up an 04 G35 that was lowered on S-techs and has Stillen sways on it. Now, I've been contemplating raising it up a bit with 350Z H-techs just so I don't scrap on things as much as I do right now. The previous owner said that the ride was 'dialed' in. It handles like it is on rails but I may want to raise it .5" or so.
- My question is, (and I've searched but didn't get a specific answer to what I am asking) what is the relationship between the sway bars and the ride height?
- If I do raise it up by putting in the 350Z H-techs, will I need to re-adjust my swaybar settings to compensate for the higher ride height?
Thanks i advance guys, I'm eager to learn about my newly acquired platform. My other car is a lifted 4runner, which has NOTHING in common with the car, lol.
Old Dec 27, 2010 | 09:27 PM
brandon1978's Avatar
Sway bars do not change ride height. A lowered car with aftermarket sways can be hard on the stock endlinks, which is why aftermarket adjustable end links are available. By raising the ride height, you will be putting less stress on the endlinks. No need to adjust sway bar settings for changes in ride height, but if you had adjustable endlinks, you would adjust the endlinks. Swaybars are for adjusting body roll and oversteer/understeer.
Be sure to get an alignment after you change the springs.
Old Dec 28, 2010 | 11:03 AM
T4RUSAF's Avatar
Thumbs up
Thanks Brandon for the reply,
So basically I can leave the sway bars set as is for now, raise the car to my liking and get an alignment, and then later re-visit my sway bar setting which would NOT affect my newly aligned vehicle, correct?
thanks again
Old Dec 28, 2010 | 12:40 PM
OBsessed's Avatar
Correct, swaybars don't have anything to do with alignment, they just increase body stiffness. Adjusting them independant of the suspension is fine, it won't have an impact on other parts.
And what year 4runner? I've got a 97 that I've been driving for about 11 years now, great truck.
Old Dec 28, 2010 | 12:58 PM
Affirm.
Old Dec 28, 2010 | 06:03 PM
T4RUSAF's Avatar
I have an 04' 4runner. One of the few that has a supercharged V8. It's a beast. Ironically, I got the G so I would put let miles on the 4runner and get better gas mileage, but I can't help but run through the gears every chance I get, lol. Gas is probably worse in my G right about now until I calm down.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
