oem brembo's with Works
Old Feb 9, 2011 | 09:04 AM
Luv2xcelR8's Avatar
Hey, I have a set of Work VS-XX's and I am wondering if the factory brembo's will clear my wheels. Offsets: F +19 a-disk; R +17 O-disk thanks in advance
Old Feb 9, 2011 | 09:06 AM
Invalid_User's Avatar
yes
Old Feb 9, 2011 | 09:07 AM
edit wait nevermind, not sure. Thought I read R disk front O disk rear .
Old Feb 9, 2011 | 09:31 AM
EL-EE-ES's Avatar
im pretty sure your going to need R disk front to clear with out the use of a spacer
Old Feb 9, 2011 | 10:02 AM
Luv2xcelR8's Avatar
Hmm...maybe I can run a 2mm spacer up front or something so that they will clear. The car is really low so the fronts are tucking at the moment but I guess I will need to raise it a bit with the front spacers so that I won't rub.
Old Feb 9, 2011 | 10:13 AM
same olg's Avatar
Are you talking about the rims Ravspec has for sale, i believe you will need a bigger spacer then 2mm to clear call Mark at Ravspec good people.
Old Feb 9, 2011 | 11:50 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
A disc up front = 15mm of space to clear brembos
R disc = bbk clearance
I know this for a fact because I measured them myself, well, at least on my T1S anyway. And T1S are more BBK friendly then the VS-XX's are. Just ask Fab.
I heard something about a T disc but not sure where that stands on the list.
Old Feb 9, 2011 | 12:06 PM
Gettinby's Avatar
I thought the "T" Disc was really BBK friendly. More so than the "R". I am assuming the "R" will clear Brembos without the use of a spacer.
Old Feb 9, 2011 | 12:30 PM
XiN's Avatar
XiN
Itasha Coupe
Yes, R disc will clear brembos.
Old Feb 28, 2011 | 11:47 AM
Luv2xcelR8's Avatar
I can't run a 15mm spacer on the fronts...they are already a +19 offset fml
Old Feb 28, 2011 | 03:15 PM
Gettinby's Avatar
I just bought a set of VSXX and they DO NOT clear Brembos in the "R" Disc. I had to use a 5mm spacer to just clear them.
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
NemesisGee
Aug 11, 2015 07:10 PM
mushu
Jul 15, 2015 03:55 PM
