Installing Coils need alignment specs
I have tried searching this on here but have had no luck,
So Im installing my BC Racing Coilovers and SPC F&R Camber kits this weekend and was wondering how am I supposed to know the camber angle I want? I went to NTB and made sure they would do the alignment for me with aftermarket coils and camber kits and they told me yes, but I need to know what specs I want them to align it too...
Thanks for any help,
Brennen
Brennen
toe alignments are fine with factory parameters. You might max out with front camber even with the SPC kit at around -2degrees depending on how low you go and if you installed the SPC shim kit for additional camber adjustment.
I thought I had my alignment sheet with me but I guess I must've left home. I'll try to post it up for you later, if I find it.
I plan on dropping so the fender is just above the top of the tire...
So about 1.5" in front and 1" in the rear?
But so there is no formula or anything to figure out how much camber I need its just an estimate? Cause I would rather not have my tires wear out super fast...
Just take it in and tell them to get as close to factory specs as possible at whatever height you choose to be right for you. Make sure you get toe in spec though, that is way more important than camber for tire life.
Thanks
What?? No, camber and toe aren't based on ride height. Changing ride height affects them but it doesn't determine what they should be set at besides the fact of trying to fit your wheels/rims. Factory spec has some pos toe, I believe it is 0.10 degrees or something like that but you can search and find the factory specs on here or your alignment store should be able to pull them up. You can set it to 0 but then it would be less performance orientated although you would get increased tire life. Then camber just try to get as close to spec ~1 degree of negative camber while still making sure everything fits fine.
Not really, as you drop you will increase negative camber just by doing that. Toe will also change due to ride height. Your camber kit is to adjust that camber back towards stock specs to preserve your tires. You don't technically need camber kits, but if you want your tires to survive longer you should. But you could just get toe back into spec and drive with whatever camber your tires end up at.
yassy
Aug 9, 2015 07:31 PM
