Questions about Air Ride suspension ask here
Rating: Thread Rating: 3 votes, 4.33 average.
Old Apr 28, 2011 | 08:28 PM
  #181
kennymo's Avatar
Originally Posted by Gorg3ou5
and how do i know if its the shocks bottoming out
easiest way would be to lay the car out. mark the tire with chock where the fender sits at. take the tires off, then take the shocks off, put the tires back on, lay the car out again and see if you went lower than you chalk mark. if you did. then its the shocks
Old May 2, 2011 | 01:04 AM
  #182
sindaddy's Avatar
im looking to replace my shocks, what a good combination with UAS bags? Bilstein?
Old May 2, 2011 | 01:07 AM
  #183
kennymo's Avatar
if you are just trying to get some replacement shocks i would go with the tixico blues or whatever that brand is. same brand that makes the d-specs
Old May 2, 2011 | 01:29 AM
  #184
XBS's Avatar
XBS
Might as well get something inexpensive since they are going to need to be replaced prematurely.
Old May 2, 2011 | 04:30 PM
  #185
hawaiinpunch's Avatar
never mind answered my own quetion..
got qouted 950+ for the kit..you think i could find it for less?
Old May 2, 2011 | 05:00 PM
  #186
sindaddy's Avatar
The difference is in the control, also with the rocker switch i don't think you'll be able to adjust the corners individually. You might want to look into getting brass fittings; the one that came with my kit were plastic.
Old May 2, 2011 | 05:02 PM
  #187
yup just read that online..thanks
damn the price on my kit keeps going up lol
Old May 2, 2011 | 09:54 PM
  #188
kennymo's Avatar
if you are talking about the plastic push to connect fittings. those are a lot better than brass fittings
Old May 3, 2011 | 02:36 AM
  #189
sindaddy's Avatar
Reno from Accuair swears by the plastic PTC fittings, but i've notice that the plastic fittings didn't "bite" into the hose as much as the brass fittings from Parker. i've read that the hose have to be perfectly flat with PTC fittings, but i'm still having leak issues... ie. my car would be fully deflated after sitting for 8hrs.
Old May 3, 2011 | 01:43 PM
  #190
Gorg3ou5's Avatar
post pics of your trunk set ups!
ken- is there a bracket needed to make the "floating tank" or you jus bolt it straight on to the top of the trunk
Old May 3, 2011 | 05:36 PM
  #191
sindaddy's Avatar
Accuair make a "floating" compressor mount, pretty cool just installed myself yesterday. but i'll be intrested if there's a floating tank mount.
Old May 3, 2011 | 08:42 PM
  #192
kennymo's Avatar
most people that do the floating look either use the accuair bracket like sindaddy said or they make there own. personally i dont like the floating look because with alot of the tanks out these days it doesnt put the drain port on the bottom. and without a water trap you will get water in your tanks from condensation that the compressors make.
also. i wouldnt reccommend putting your compressor upsidedown either because the cooling head is meant to be on top. if you flip it upside down like i have seen people do it can overheat a lot faster which is always bad
Old May 4, 2011 | 10:48 PM
  #193
blAk mAx's Avatar
disadvantages of bags?
Old May 4, 2011 | 11:03 PM
  #194
kennymo's Avatar
uhm...not quite as good handling as coils but pretty good still. and if its installed wrong or you get ****ty parts it will fail. but thats true for everything
Old May 4, 2011 | 11:10 PM
  #195
blAk mAx's Avatar
what about those bags that fit over coils?
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
