Questions about Air Ride suspension ask here
run 4 gauge for the main power and normal speaker wire for everything else will be fine. as for the relay a lot of people use a normal 30/40 relay but those tend to go out so i always reccomend that people use a stinger 80amp relay. you can use 1 to run 2 compressors.
http://www.google.com/products/catal...d=0CCkQ8gIwAQ#
you can save yourself a few bucks on an auto leveling system by going with the dakota digital system. it eliminates the big switch box, gives you three presets, and includes a digital display. the downside of it versus the accuair system is that it takes slightly longer to get to the preset heights so you'll hear the valves click open & close more often.
whatever way you go, it really is much more convenient to have presets...no need to mess with a big switch box while driving or worrying that your alignment is off
In my opinion, it's definitely worth it for the Accurair system if you can. Fittings and all that stuff gave me headaches for months before I took out a whole box of **** for just one little box. I'm also running gaugeless right now, and it's still worth it...
Does anyone know where I can purchase the autoleveling system for the Accuair system? I already have the controller.
