Questions about Air Ride suspension ask here
Rating: Thread Rating: 3 votes, 4.33 average.
Old Feb 7, 2012 | 03:39 AM
  #271
G35pm's Avatar
I'm seeing some very tiny cracks(~1-1.5mm long, very narrow) on the exterior of my bags, should I look to replace soon? No signs of leaking. Thanks.
Old Feb 14, 2012 | 02:10 AM
  #272
CHAMUKO's Avatar
im in the middle of putting my rear airbags and i want to be slammed!!! i"ve test fitted the rear bags and it seems like my shock wont let me go lower then i would like!! has anyone gone through this???? any help would be appreciated!!! thnx
Old Feb 14, 2012 | 02:35 AM
  #273
G35pm's Avatar
Get shocks with shorter bodies?
Old Feb 14, 2012 | 07:21 AM
  #274
CDN_G35's Avatar
Its your bump stop.. You need to remove that and cut some of it off for you to be able to go lower. Hope this helps.
Old Feb 14, 2012 | 03:12 PM
  #275
OBsessed's Avatar
I'm beginning to think this is the way to go, I love the idea being low and static but it's just not practical where I'm at. Couple questions though before I start piecing things together...
The parts list in post #2 looks like it was last edited last year, is that still the way to go or does anyone have suggestions for things they'd do differently?
Ride quality: I know it's going to be worse than my BC Coilovers when they were first installed and unmolested, but how does it compare to stock - assuming sway bars set on full stiff?
Handling/Performance: I'm not going to be drifting or taking it to the track, but I enjoy driving on curvy roads, should I be worried?
I love the way my car looks low but it's almost undrivable at the moment so it's not doing me a whole lot of good. Would love some input from the pros on the above.
Thanks for the great thread and info, any feedback would be great.
Old Feb 14, 2012 | 06:37 PM
  #276
Manhattan Project G's Avatar
So, stupid question, perhaps, is this a stand alone solution? Whats the approximate cost of a kit?
EDIT: Plus what leksikon said
Old Feb 14, 2012 | 09:28 PM
  #277
CHAMUKO's Avatar
... sorry but whats a bump stop and where is it located lol ?? thnx again!!!
Old Feb 14, 2012 | 09:36 PM
  #278
CHAMUKO's Avatar
cdn_g35 .... did u have to use other shocks than the oem ones to be that low?
Old Feb 18, 2012 | 12:19 PM
  #279
Z's G's Avatar
I have the two front bags brand new if anyone wants them send me an offer. Thanks
Old Feb 20, 2012 | 01:21 AM
  #280
kennymo's Avatar
how old are the bags that you are talking about? 1-1.5mm is REALLY small and i would not be worried about it. the bags i have on my current project look like **** and have tons of those 1-1.5 cracks in them. its normal and unless they start getting big or the bag starts leaking i would not worry about it.
Old Feb 20, 2012 | 01:24 AM
  #281
kennymo's Avatar
The parts list in post #2 looks like it was last edited last year, is that still the way to go or does anyone have suggestions for things they'd do differently? those are still all very common parts and i would still recommend them to anyone.
Ride quality: I know it's going to be worse than my BC Coilovers when they were first installed and unmolested, but how does it compare to stock - assuming sway bars set on full stiff? the ride should not be worse that coilovers at all. they it should actually be a very nice/smooth ride. unless you are driving around aired up all the way or aired out completely the ride should be nice
Handling/Performance: I'm not going to be drifting or taking it to the track, but I enjoy driving on curvy roads, should I be worried? there are a lot of autox people that run air ride setups on there cars and they still do great.
answered
Old Feb 20, 2012 | 01:35 AM
  #282
kennymo's Avatar
on the parts that i listed in post #2, i recently installed most of the same parts on my newest project (69 galaxie)
im using the same REAR bags that i suggested
the same switchbox
the same pressure switch
the same valves
http://www.facebook.com/media/set/?s...3367547&type=1
Old Feb 20, 2012 | 01:39 AM
  #283
CDN_G35's Avatar
Bumpstops are located on your shocks, they prevent the shock from completely bottoming out. Its illegal to run without them but you can make them quite a bit smaller. I've upgraded all my shocks on my setup but yes you can be this low with oem shocks! Hope this helps
Old Feb 21, 2012 | 11:14 PM
  #284
DGrantG's Avatar
Yeah... Just read all 19 pgs... I'm gonna start piecing a kit together...
Old Feb 21, 2012 | 11:20 PM
  #285
DGrantG's Avatar
So what all fittings are needed? Just threaded to ptc to connect to valves and tank or are there other ones need as well?
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
