gtr bbk on g35?
Old Mar 28, 2011 | 03:11 PM
g3fly's Avatar
gtr bbk on g35?
What do I need to make the brembos off the gtr r35 fit? Just a bracket right? I wanna know before I get them. They come with the oem rotors too. Btw I got my g35 oem brembos on right now. So just wanna upgrade
Old Mar 28, 2011 | 04:04 PM
G35fromPA's Avatar
What you need are the specs on the GTR brakes, because it's highly likely that the brake bias on the GTR is quite different from the G35 - probably different master cylinder too. you can't just slap 'em on and assume they will be better. They may look better, but you could be hurting the car's braking performance by overbiasing the front, for instance.
Old Mar 28, 2011 | 04:13 PM
O HELLA OEM's Avatar
Someone on my350z put r35 gtr brakes on his red 350z
Old Apr 5, 2011 | 01:43 PM
P10 WRC's Avatar
i don't know, but i will take those stock brembo's off your hands when you do upgrade
Old Apr 5, 2011 | 06:47 PM
bigc's Avatar
Wings Nation
Search threads created by E K. He installed the OEM front brembos from the new GT-R on his G and made a progress thread. If you sort by date you should see it near the top.
Old Apr 5, 2011 | 06:54 PM
WhosUrBuddiee's Avatar
Horrible idea. The replacements rotos and pads alone are worth 25% what your entire car is.
CandlestickPark's Avatar
ill Sedan
E_K's thread that bigc referenced:https://g35driver.com/forums/media-s...ton-setup.html
Old Apr 5, 2011 | 08:20 PM
SDGenius's Avatar
Not worth it, i've seen OEM GT-R Brembo's listed for $5k. you can have a legit BBK setup designed for you're car for less. if you really want to upgrade performance, just get 2pc rotors and SS lines. if you wanna upgrade size and appearance, do Akebono, Willwood, Megan or Alliance.
Old Apr 5, 2011 | 09:13 PM
bigc's Avatar
Wings Nation
the FM1000 pads they sell for their monobloc kit (similar) cost 479 (f) / 279 (r). Rotor rings are about 2 bills each.
I agree though, there are more cost effective options out there, particularly since you'll need to have a custom bracket made.
Old Apr 5, 2011 | 09:42 PM
GreenGoblin's Avatar
The goblin resurrection
I have done it, here it Lowell's thread
http://my350z.com/forum/brakes-and-s...ff-an-r35.html
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
