front Toe spec
Old 04-19-2011, 02:17 PM
cturnbull802's Avatar
i was wondering if you put anything under the tires to let them slide easier on the garage floor
  #32
Old 04-19-2011, 02:32 PM
Deezflip's Avatar
Originally Posted by sTeadFasT96
Isn't there something about the car causing the toe to change when at speed anyway? So don't you actually avoid being directly at 0 toe?
this is correct, well, not necessarily speed but the drive wheels produces flex when trying to push/accelerate the car forward. Same thing with the non-drive wheels which flex when it's being dragged.....
http://www.aa1car.com/library/wheel_alignment.htm
is it safe to assume that there's less flex since lowered cars with more camber have less road-to-tire contact, which is why most want the toe closer to 0?
  #33
Old 04-19-2011, 02:39 PM
Deezflip's Avatar
Originally Posted by cturnbull802
how do you adjust toe at home? i was just going to try and measure front side of the wheel and back side of the wheel and make them match with the suspension loaded on jack stands
you can use two floor vinyl tiles sandwiched together with grease in the middle, but becareful when all four tires are on it since the whole car might shift and give you false readings if your taking measurement from a stationary object. It's better to do two wheels at a time and not all four, to keep the car stationary. This is the reason why it's better to have actual wheel alignment plates since they provide slip but limited in movement, but they can be costly.
here try this,...
http://elantragtclub.tripod.com/elantra/id554.html
  #34
Old 04-20-2011, 12:28 AM
onthe3rdday's Avatar
Originally Posted by whoisthis
Gdup35sedan: not answering me
Do you have a pic of camber and toe aligning set up? i prefer to buy this alignment DIY set up then buying a lifetime warranty alignment at a mexican place.
Lifetime warranty alignment doesn't seem so bad. If you know what you want from your alignment and have a basic understanding of the suspension geometry and suspension "vocabulary", you can get what you want from it.
  #35
Old 04-20-2011, 01:53 AM
whoisthis's Avatar
here try this,...
That link is very helpful. Thanks.
If i can find someone who would like to be my "partner" to get alignment done in my garage, it'll be awesome. We can get the alignment done on each other's car.
I have some knowledge about alignment. The alignment guys are just stupid lol
i went to couple of NTB shops but they denied to do it since my car is too low for their crappy rack. I would need to remove the front and maybe sideskirts to MAYBE get on the rack.
  #36
Old 04-20-2011, 02:12 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Sorry man. Yes if you're down here I can do your alignment. Buying all this stuff for personal use isn't recommended. It costs quite a bit to just use it on your car alone.
  #37
Old 04-21-2011, 01:24 AM
whoisthis's Avatar
For how much can you do it for?
Also i have a question. I got my alignment done. They hand aligned so i have no way of confirming but they told me that front and rear toe are set to 0. front camber is around -2.4 left and right. left and right are not exact but they are pretty close to each other. Less than +-.7 i think.
The weird thing is that the space between the fender and the sidewall is different from left and right. On one side, i can put my fingers through going upward. Can't move wiggle around the fingers much. On the other side, i can wiggle around my fingers between the space.
Did the alignment guy lie to me about the camber number?
  #38
Old 04-21-2011, 08:21 AM
front or back? because in the rear of the car there is slightly more room on one side of the car than the other. that and in the rear there is usually a height difference of a few mm from drivers to passenger side due to sloppy uper spring mounts.
  #39
Old 04-21-2011, 04:14 PM
whoisthis's Avatar
its the front. I don't have adjustable camber arms
  #40
Old 04-21-2011, 05:55 PM
+/- .7 is a HUGE difference in camber settings, and even bigger difference in toe.
Thats almost a full degree of cross camber. Cross camber should always be within 0.2.
  #41
Old 04-21-2011, 08:14 PM
whoisthis's Avatar
actually he said one side is -2.25 and other side is between -2.4 n -2.5
  #42
Old 04-24-2011, 01:30 AM
whoisthis's Avatar
i measured the space, and it came out to be .188" difference left and right in space between the fender and the sidewall. how much camber difference would this be?
  #43
Old 04-24-2011, 04:05 PM
none. the tires is closer to the fender on one side of the car. its the same on z's and g's
anyone ever notice the rear diff isnt center under the rear of the car?
  #44
Old 04-24-2011, 04:28 PM
whoisthis's Avatar
When i used to have SPC a arms, both sides were same
EPG35
08-16-2015 04:52 PM
underworld
08-06-2015 01:36 PM
itschuckster
07-25-2015 08:07 AM
jimNC
07-25-2015 05:47 AM
Quick Reply: front Toe spec
