eibach springs installed and now weird clunking noise from front pass suspension
Old Apr 6, 2011 | 09:09 AM
0MGHI2U's Avatar
ok so i got a 06 g35 coupe with sport tuned suspension.. i installed Eibach pro kit springs and only the front passenger side suspension is making a weird popping/cluncking noise (sounds as if something was loose)when goin over bumps (not small ones) but if i duplicate it on the other side it don't make a sound at all.. i took it to the shop that installed it and they said everything was on correctly and torqued to specs.. so what could be the issue?
*no leaks on shocks*
Old Apr 6, 2011 | 09:49 AM
B FIFE22's Avatar
Maybe your front passenger endlink? My rear endlinks wore out and whenever I went over speed bumps or the car swayed side to side over uneven pavement they would make a clunking noise. After they were replaced it was gone.
I'm sure someone with more experience will have other possibilities on what it could be.
Old Apr 6, 2011 | 10:07 AM
0MGHI2U's Avatar
hm.. ok imma have to look at that after work... when i was on my stock sport springs i never had an issue with my oem endlinks and hotchkis sway bars..
Old Apr 6, 2011 | 06:55 PM
0MGHI2U's Avatar
endlinks are good, lower control arm is good.. bolts are all tight.. nothing is lose or damaged.. i cant find out what it is. W T F... ANYONE?
Old Apr 6, 2011 | 06:56 PM
nogoodname's Avatar
Compression rod bushing or ball joint is probably finished.
Old Apr 6, 2011 | 09:05 PM
Keggr626's Avatar
Mine makes the same noise in the back but on oem springs... I'm gonna get this checked out
Old Apr 6, 2011 | 09:09 PM
Jevangel's Avatar
Weird. Mine does the same thing, but on the front driver side. Only over bumps just like you. Suspension got looked over during my 60k though, and I was told everything looked good so I have no clue what it is.
Old Apr 6, 2011 | 10:26 PM
lcysimon's Avatar
Mine makes the same noise on OEM suspension from the rear. It goes "clik click" when I go over speed bumpers about 20 mph or any bad roads.
I thought it was the endlink and replaced it, but that wasn't it.
My next best bet is the compression rod.
Old Apr 7, 2011 | 02:30 AM
Choleaoum's Avatar
more then likely it's probably the little bushing/bearing in your top hat. my car use to go click click click but that was because my wheel wasnt torqued down properly lol.
on a civic i did a install, i tried troubleshooting everything, then came to realize it was the top hat. my coilovers bags are like that too right now, the pillowball bearing is making noise.
Old Apr 7, 2011 | 02:36 AM
Keggr626's Avatar
Mines more of a thump then a click... sounds like u might have the infamous clicking axle
Old Apr 7, 2011 | 08:09 AM
0MGHI2U's Avatar
so top hat? this thing? http://cgi.ebay.com/ebaymotors/2003-...Q5fAccessories
do i have to take apart the struts and shocks to install it?
Old Apr 13, 2011 | 04:07 PM
Keggr626's Avatar
Alright went to my friends shop had him lift the car up. He checked everything out and when moving the rear stabilizer bar we heard the clunking noise coming from the endlinks so most likely that is the cause of the problem... haven't swapped them out yet but when I do I will post an update
Old Apr 14, 2011 | 09:53 PM
RacerGX's Avatar
I had same problem on my 07'. Went to dealer this morning, by 2pm they had replaced the end link and control arm (rod). It's like brand new, so quiet. My car only has 37k, hope I'm not back again after warranty. Wonder if this is covered by drivetrain warranty for 2 more years. Dealer was awesome about it, although I had to take them for a spin to convince them.
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
cyrus32
Jul 18, 2015 06:22 PM
