Uneven brake pad ware?
Old Apr 20, 2011 | 05:11 AM
jin22gt's Avatar
I had to change my rear pads and rotor today bc the rear passenger side pad was completely gone and eating up the rotor.
My question is, the other rear pad still had around 30% of pads left while the passenger side pads were gone. Only the metal end was left.
Shouldn't the pads be around the same? Why is one side completely gone, while the other side still good??
Both rear pads/ rotors were changed at the same time last 1.5years ago.
Old Apr 20, 2011 | 08:06 AM
vp-g's Avatar
same here when i changed my pads the passenger side was gone. these were on brembo also.
Old Apr 21, 2011 | 04:16 AM
datbeans's Avatar
Maybe Braking and turning? (Guest shot from the dark)
Or they way nissan proportioned the brake pressure to that one particular side??
Old Apr 21, 2011 | 01:57 PM
MikeDG's Avatar
Was the piston siezed or stuck on that side?
Old Apr 24, 2011 | 01:06 PM
onthe3rdday's Avatar
Uneven pad wear = rebuild your brake calipers..Something caliperwise is sticking, binding, frozen etc. Google DIY brembo caliper rebuild or something similar to that. Rebuild kits for Brembo calipers are extremely inexpensive. Lastly, there could be an obstruction in the line somewhere. So check lines and hoses.
Old Apr 30, 2011 | 03:51 PM
huyqvu's Avatar
just did my rears today. on both sides the pads were down to the bare metal and the outer pad had maybe half still there compared to new ones. the guide screws seized and had to end up ordering new calipers and rotors.
Old Jun 16, 2011 | 01:45 PM
supergmurder's Avatar
im having the same problem with my non brembo rear pads. the passenger side woar away in weeks. the drivers are like new.
BradMD_96
Oct 6, 2015 09:31 AM
alinero718
Sep 27, 2015 09:35 PM
vamarris
Sep 26, 2015 12:56 PM
NJ6MT
Sep 10, 2015 08:40 AM
