Front Camber Arm Kit recommendations?????
Old Apr 20, 2011 | 02:55 PM
cshearer03's Avatar
I just bought a 04 6mt last week and it is lowered. But the original owner didnt replace the front A arms to get the camber into spec. He was told by his shop that he didnt have to. It needs them. I have noticed some complaints about the Ichiba camber kits. Does anyone have any other companies they would recomend or stay away from??? I saw some from megan racing and they are inexpensive but afraid they are cheaply made also. Any help would be appreciated!!!
Clayton.
Old Apr 20, 2011 | 02:58 PM
Hi-TechG35's Avatar
Get the Stillen ones. They are a little pricey but well worth the money. Offers a lot of adjustment and will definitely get you back into spec.
Old Apr 20, 2011 | 03:48 PM
toro12's Avatar
20 Year Member
Lowered is definite need for positive camber adjustment if expected tire life is to be in specification after alignment. The OEM arms are fixed for alignment to stock OEM suspension height.
You should have a look at "SPC Performance" fronts which are (2) part designs that are cost effective.
The arm offers about +1.3 degrees in the arm slot which is adjustable. An additional +1.5 degree correction comes from fixed angle tapered shims which mount behind the wheel hub and brake caliper.
Total positive camber is claimed to be around 3 degrees total, which is usually enough for even 2 in drop.
More then 1 in. suspension drop you need to be using the shims.
Old Apr 26, 2011 | 05:02 PM
jimmykce1's Avatar
Running SPL adjustable camber on my sedan.
Old Apr 26, 2011 | 05:28 PM
FenixL1P's Avatar
jimmy, how's the wear on your tires?
Old Apr 28, 2011 | 12:02 AM
Gettinby's Avatar
Stillen here. No complaints.
Old Apr 28, 2011 | 12:04 AM
JBF's Avatar
JBF
first post is a question that has been asked and answered thousands of times.
Cluttering up the forums with this crap is getting really annoying
Old Apr 28, 2011 | 12:08 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you want the highest quality arms with easy adjustment, go with SPL V3 A-Arms.
They are $565 but well worth the money.
The SPC/Eibach/Megan/Ichiba A-arms all have bushings that will wear out quickly and you'll be left with squeeks and a loose suspension feel.
Old Apr 28, 2011 | 12:09 AM
It's a never ending cycle, John. There's always going to be NOOBS cluttering the forums.
Old Apr 28, 2011 | 12:41 AM
highoutput's Avatar
have them to they are great!
rezendvous420
May 31, 2020 01:26 PM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
