Energy Suspension Front End Kit Installed!
Old Jun 27, 2011 | 01:04 PM
vinco's Avatar
I don't remember what I did on mine. I started to say that I just lubed the inner part, but I might have done the outer also. I'll have to look at it again next time I get it up on the lift. No squeaks yet on mine after 5K+ miles.
Old Jun 27, 2011 | 01:18 PM
AlexB's Avatar
Actually I just called ES to find out for sure and it turns out the lube can only go on the inside of the swaybar bushing.. Good thing I got it right...
Now my next step is to replace the ball joints without breaking the bank
Old Jun 27, 2011 | 01:32 PM
Deepdiver's Avatar
Good review...thanks for the info.
Old Jun 27, 2011 | 02:26 PM
vinco's Avatar
Ebay is your friend on the balljoints.
Old Jun 27, 2011 | 02:42 PM
AlexB's Avatar
Vinco - do you know if the aftermarket lower balljoints on ebay are reliable?
Old Jun 27, 2011 | 02:45 PM
vinco's Avatar
I have no information on that, but I have read that they fit well. They've got to be better than riding around on worn out originals. Actually, the originals are probably made in China anyway.
Old Sep 8, 2011 | 01:57 PM
keithk831's Avatar
If all i'm replacing is the compression rod bushings, will I need to get an alignment afterward? My tires and alignment appear to be ok right now.
Old Sep 8, 2011 | 01:59 PM
vinco's Avatar
I haven't gotten an alignment, and I've been driving on my ES front end kit for 11K miles so far with no noticeable tire wear.
Use LOTS of lube on the CR bushings!
Old Sep 8, 2011 | 02:18 PM
keithk831's Avatar
On which surfaces? Everything that touches something?
Old Sep 8, 2011 | 02:20 PM
vinco's Avatar
Yes, everywhere the poly pieces touch metal.
Old Sep 8, 2011 | 04:49 PM
datbeans's Avatar
Hey vincO, I don't wanna thread jack but it seem like a waste
Starting a whole separate thread...
I did the install but are the bushings surpose
To sit this way?
Notice the gap? Is that normal? Or did I fudge up the install?
Old Sep 8, 2011 | 04:57 PM
vinco's Avatar
Mine looks pretty much the same. Just hit the nut one more time with your breaker bar to be sure it's got plenty of torque on it. Is the car jacked up at all in this picture? If the car's weight isn't on the wheel, then it especially looks like that. The bushing is back cut where the barrel meets the aluminum arm, so it allows it to pivot a little bit. I think that's what you're seeing.
Old Sep 8, 2011 | 05:19 PM
datbeans's Avatar
Yea the car is on the ground thanks for the input..
I was using an air impact wrench so I hope
I tighten every thing snug. Driving wise the car feels
So much firm and the noise is gone Finally !!
Old Sep 9, 2011 | 02:19 AM
keithk831's Avatar
It's always smart to check bolts with a breaker bar/torque wrench after using an impact wrench. Tire places do it for lug nuts...
Old Sep 9, 2011 | 02:45 AM
  #30
zeroscythe's Avatar
Great write up.. Definitely gonna be my next mod
