Energy Suspension Front End Kit Installed!
Old Dec 8, 2011 | 04:47 PM
  #61
redpearl99's Avatar
this news about the ES compression rod bushings squeeking in cold whether is quite troubling, I wanted to change my OEMs to ES in the spring but now this has gotten me thinking twice
Old Dec 8, 2011 | 05:35 PM
  #62
P10 WRC's Avatar
i only installed the inner and outer lower control arm es bushings. i will report back if i ever have an issue. I am def not installing the compression bushings though after reading what you guys are saying
Old Dec 8, 2011 | 05:39 PM
  #63
redpearl99's Avatar
^ yea but you're from Arizona so I doubt your weather is even close to being as cold as Canadian/north Eastern weather
Old Dec 8, 2011 | 06:40 PM
  #64
P10 WRC's Avatar
yeah it gets down to the low thirties in the winter
Old Dec 8, 2011 | 07:13 PM
  #65
redpearl99's Avatar
I would beg to have low 30s
Old Dec 8, 2011 | 07:20 PM
  #66
keithk831's Avatar
Amen to that! I grew up in South Florida...living in Utah the past six years I curse the cold/snow every time.
Here's a question: I paid a shop to install my ES compression rod bushings because some of the bolts were on there really tight, and I didn't have a deep socket set. I'm thinking that since they "broke" the factory seal, I might be able to do this myself (removing the ES bushings, and installing the new factory bushing). Is this something I can do myself, or would a press be needed?
Old Dec 8, 2011 | 08:31 PM
  #67
redpearl99's Avatar
you'll definately need a press for an new oem bushing. But at least you'll know your compression rod will come off easily since it was recently taken off
Old Dec 8, 2011 | 11:09 PM
  #68
Cooldude04's Avatar
Originally Posted by keithk831
Does anyone know/think that a good grease would permanently (or at least for a couple years) remove the noise? I used anti-seize when I installed it. Would I need to take it all apart again to grease it properly?
I'm just looking at my options before I decide to do anything here.
I've used a lot of anti-seize before and even after i installed the ES bushing but the noise is still there. It was quiet for about a few days and then it came right back. I even lubed the hell out of them again but it just came right back regardless. I dont think it's gonna be quiet for a few years, the longest time it was quiet for me was about 2 and half weeks.
About to grease it again, I didn't take them out I just remove the brace underneath and then I use WD40 and anti-seize.
I've been trying to find a revised OEM CR bushings but no luck so far
Old Dec 8, 2011 | 11:16 PM
  #69
keithk831's Avatar
I know a lot of people use anti-seize...I wonder if grease would be better for longevity...?
Old Dec 9, 2011 | 10:58 AM
  #70
CLEANBS's Avatar
contact OC infiniti for revised CR bushings
Old Dec 20, 2011 | 11:44 PM
  #71
redpearl99's Avatar
any updates on how the ES bushings have been holding up in cold climates?
Old Dec 21, 2011 | 01:18 AM
  #72
keithk831's Avatar
I don't know if it's just me trying to ignore it, but it seems like the squeaks have lessened for now. But it has been a bit more humid lately.
Old Dec 23, 2011 | 06:46 AM
  #73
whiteline's Avatar
An option for you guys is we just released our compression rod bushing and have no doubt your noise issues would be a thing of the past and we back it with a lifetime warranty
http://www.whiteline.com.au/product_..._number=W83389
Old Dec 23, 2011 | 11:55 AM
  #74
redpearl99's Avatar
Special pricing?
Old Dec 23, 2011 | 01:42 PM
  #75
keithk831's Avatar
Special pricing?
X2. Call it the "Get the ES crap off my car" deal!
