Energy Suspension Front End Kit Installed!
Old Jan 14, 2012 | 12:05 AM
  #106
Row2k's Avatar
20 Year Member
G35 Coupe
i have a mix of polyurethan whiteline bushings (lower control arm) and SPL bushings throughout the car. Haven't heard my whiteline poly bushings squeek even once and I've had them in for something like a year + now. Even now in cold ars weather. I'm finding it very surprising that the polyurethane Energy bushings are so squeaky....they're just about the same thing ....hmmmm
Old Jan 14, 2012 | 12:17 AM
  #107
redpearl99's Avatar
Some have reported squeaks with Whitelines as well
http://forums.evolutionm.net/evo-tir...d-climate.html
Old Jan 14, 2012 | 12:37 AM
  #108
Row2k's Avatar
20 Year Member
G35 Coupe
oookaay
... guess ill be replacing those with SPL eventually
Old Jan 14, 2012 | 02:31 AM
  #109
HeelToeSTi's Avatar
Giving the bushings a shot of spray lube every two months does not seem unreasonable to me for the benefits. Seems like if you change your oil or stuff is squeaking... jack it and spray it. :-)
Mine goes on in the spring. Complete kit. I will post my experience.
Old Jan 14, 2012 | 07:20 PM
  #110
Wilg35j's Avatar
I changes my lower control arm bushings with es ones and they squeak like crazy
Old Jan 14, 2012 | 07:46 PM
  #111
redpearl99's Avatar
Damn this world!!!!
I guess im just going to go with the Nismo harder rubber bushings, better than OEM but not as strong as poly, but also without the squeak
Old Jan 15, 2012 | 09:59 PM
  #112
moto_za's Avatar
I ended replacing all my front busing with the ES kit I had bought. I am really pleased with the bushings. So far I don't have any additional squeaks, but the previous squeak I would get over bumps is still there. While we were installing them, I noticed that my ball joint is leaking on both sides so maybe the squeak is from there?? As far as handling, ride, performance, etc I cannot be any more happier. Great upgrade IMO. I am wondering if changing the rear bushings would be worth it??
Old Jan 15, 2012 | 11:23 PM
  #113
Row2k's Avatar
20 Year Member
G35 Coupe
Originally Posted by redpearl99
Damn this world!!!!
I would recommend you do a combination of SPL and Nismo bushings. That's exactly what I did for my rear knuckle and control arms. Essentially pick and choose which ones would have the biggest effect on Toe and Camber changes while cornering and use SPL, then use Nismo for the rest.
I'll prob do this for the LCA once my whitelines start making noise: SPL for innermost bushing and nismo for shock mount bushing. I think its a descent compromise.
Old Jan 15, 2012 | 11:35 PM
  #114
redpearl99's Avatar
yea I would love to do SPL and Nismo, but they're so damn expensive compared to poly or OEM bushings
the Nismo lower control arm bushings alone cost $110 for the pair
Old Jan 15, 2012 | 11:36 PM
  #115
Frankieg35's Avatar
Squeeks drive me crazy!!
  #116
moto_za's Avatar
Did you notice a good difference when changing the rears?
Old Jan 16, 2012 | 11:57 AM
  #117
Row2k's Avatar
20 Year Member
G35 Coupe
I did notice a difference, but it certainly wasn't huge nor nearly as obvious as changing out the lower control arm bushings with whitelines and compression rod bushing with SPL. The front bushings were immediately noticeable as soon as you pitched the car left or right a few times with the wheel. The rear knuckle bushings on the other hand are only much more noticeable when you start putting a lot of lateral stress on the rear end and I never took my car to the track before installing them so its hard for me to comment.
Honestly I would only change out the rear knuckle bushings if you intend to track the car, otherwise it's not really worth the time and effort or just change out the diff bushings to solid ones, I felt like that made a bigger difference than changing out the knuckle bushings.
Old Jan 16, 2012 | 10:47 PM
  #118
moto_za's Avatar
^Thanks man. I will look into replacing the diff bushings.
Old Feb 4, 2012 | 04:07 PM
  #119
Morgan's Avatar
so, have any body positive comments after using Energy Suspension bushings??? as i understand, first and main reason for squeaky noise is incorrect installing/greasing???
Old Feb 11, 2012 | 09:18 AM
  #120
TITANG9's Avatar
G35 RWD AUTO
Any input on this? I'm about to order ES bushings.
I live in Puerto Rico (mostly 75 to 85 temp) ...also, very humid.
