SPL Compression Rod Bushings, A-Arms, New hub assemblies... Feels like a new car!!!
Old 05-11-2011, 09:42 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Just got done installing the following:
SPL V3 A-Arms
2x Nissan Hub Assemblies
All I can say is WOW! I didn't remember what driving my car with functional compression rod bushings felt like, The steering is tighter and the front end overall feels so much better!
Old busted bushing:
New SPL Solid bushing:
Installed:
New hub with Ichiba extended studs installed (running 10mm spacers)
I'll be installing the following in 2 weekends:
Tein Inner Tie Rods
Whiteline Front LCA bushings
Whiteline Front LCA shock bushings
Old 05-11-2011, 09:49 PM
CandlestickPark's Avatar
ill Sedan
Received 2,687 Likes on 1,448 Posts
Good stuff Grant! Glad to hear these mods improved your handling.
Old 05-11-2011, 09:51 PM
Invalid_User's Avatar
Your wheel bearings go out?
Old 05-11-2011, 09:56 PM
No they didn't go out. I had the SPC camber brackets on with the ABS relocation brackets and the abs sensors rubbed on the hub causing the ABS/SLIP/VDC lights to come on. That was a cheap temporary way to get more positive camber.
So I finally decided to do it the right way and get new A-Arms and ditch the shims, so the hubs needed to be replaced to get the lights off for good.
Old 05-12-2011, 04:48 PM
FenixL1P's Avatar
did you get vibration when braking from 50-20mph before?
i gotta start troubleshooting cr bushings and brakes before i spend too much money... would love the spl cr bushings though.
Old 05-12-2011, 05:19 PM
lox1985's Avatar
Recently, I've been reading that SPL compression rods are starting to make crazy noise after awhile even if the are lubricated correctly? Due to the bushing being metal...any thoughts?
Old 05-12-2011, 06:49 PM
I did not have vibrations before. My car is lowered 4" so I wouldn't notice if it did vibrate before.
So far I've noticed that I'm not bottoming out on dips or imperfections in the road were I used to. I also don't scrape the front bumper going down the driveway like I used to as well so it definitely make the whole front end more rigid and stable
Old 05-14-2011, 01:13 AM
whoisthis's Avatar
ask SPL for sound dampening o-rings for your compression arm bushings
Old 05-14-2011, 10:13 AM
I have the latest version of the CR bushings that came with the o-rings.
Old 05-14-2011, 10:19 AM
whoisthis's Avatar
did you get the white or black ones?
I have white ones installed but apparently they are little too soft. so I have black ones, stiffer.
Old 05-14-2011, 09:26 PM
I have the white ones right now. If they start making noise then I'll call SPL and get the black ones
Old 05-14-2011, 09:37 PM
The-Dream's Avatar
What's the SPL V3 A-Arms?
Old 05-14-2011, 11:20 PM
The latest version of SPL's A-Arms (front camber kit)
Old 05-15-2011, 12:39 AM
04G35NYC's Avatar
Hows the ride quality? I need mine changed and i have no idea what to get OEm, these or the other bushings.
Old 05-15-2011, 12:51 AM
They're solid! Literally and figuratively. If you want to retain any comfort, go with whiteline or energy.
Quick Reply: SPL Compression Rod Bushings, A-Arms, New hub assemblies... Feels like a new car!!!
