Clicking Noise Front of Car
Old May 14, 2011 | 03:35 PM
smeres's Avatar
I began to hear a thumping noise when driving above 5 mph. Rear of G wheels.
Sam - Baltimore
Old May 15, 2011 | 05:40 PM
smeres's Avatar
Has anyone heard of this issue before?
Old May 16, 2011 | 12:09 AM
onexxxv's Avatar
i kinda got the same issue, but its just coming from the front left. and also its when i brake slowly.
Old May 16, 2011 | 02:28 PM
Zonedriven's Avatar
I had a similar noise and finally replaced the sway bar ends and fixed it all. $200 total.
Old May 16, 2011 | 02:48 PM
irishsig's Avatar
I had this exact clicking issue.
I could especially hear it when I was going about 2-5 mph and turning.
It ended up being the well known "axle click".
The dealership just had to relube the axle.
There is a DIY on the boards some place.
Old May 16, 2011 | 02:54 PM
irishsig's Avatar
Found this DIY
http://my350z.com/forum/engine-drive...rear-axle.html
Old May 16, 2011 | 03:39 PM
ASTran's Avatar
@ smeres, you said, "I also hear a slightly different "click" or "grind" noise when I pull into a parking spot and make a sharp turn at low speed. Happens when wheel is turned really far."
I had the same problem also. I greased the bearing on the hat of the front struts, and the clicking noises were gone. In addition, if you have aftermarket swaybars then the clicking noise is coming also from the front endlinks. You will need adjustable endlinks.
dphillips2011's Avatar
pop the hood and use a flashlight to check out the serpentine belt. mine was so chewed up it wasn't even funny and I've only got 80k miles on my G. Its right at the front of the engine behind the front bumper.
I had the same issue as you and this fixed it easy.
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Joshua615
Aug 31, 2015 12:29 AM
cyrus32
Jul 18, 2015 06:22 PM
papo020
Jul 17, 2015 10:30 PM
