Energy suspension compression rod bushings
Old May 18, 2011 | 04:39 PM
5150DS's Avatar
Anyone running these? I just ordered some from z1 motorsports and was wondering what others think of them.
Old May 18, 2011 | 11:00 PM
04G35NYC's Avatar
I would like to know as well, since i need to change mine asap.
Old May 18, 2011 | 11:44 PM
5150DS's Avatar
I bought used spare arms for $136 shipped, both sides from ebay. The bushings were about $75 shipped. I will have them pressed in when they arrive next week. I am sure they will be alot better than the current ones that have 120k miles on them. I am sure they have been torn for awhile and it is annoying the way the car feels. I will put an update up after they are installed.
Old May 19, 2011 | 09:44 AM
MikeDG's Avatar
I installed the Energy Suspension CR bushings a few weeks ago. So far I am happy with them. They got rid of my squeeks and creaks and made my car feel much more solid at high speeds.
Also, you don't need a press to get them in (just need one to get the old bushings out). I put mine in the freezer for like an hour and was able to press them in by hand most of the way. Then I used a large C-clamp to get them in the rest of the way.
Old May 19, 2011 | 11:17 AM
Sylvan lake V35's Avatar
Whiteline is going to be making the bushings soon, they are sending me a prototype set to try out.
Old May 19, 2011 | 12:47 PM
FenixL1P's Avatar
Looks like I'm gonna have to bug my mechanic buddy to use his press for many of my upcoming vehicle rehab work... compression rod bushings, wheel bearings, clutch throwout bearing, etc... I'm hoping it can go 250K+ miles... do they make sway bar bushings for stillen sway bar?
Old May 19, 2011 | 05:35 PM
5150DS's Avatar
Cnsidering the stock ones work for Stillne I would assume the Energy ones work. If you are doing cr and sway bar you might just buy the whole front end kit.
Old May 20, 2011 | 11:51 PM
O4G35DPM's Avatar
ES front kit soon...
I am going to be putting the ES front kit on, although I can't "see" anything wrong with each of the bushings, but the bad handling and sounds are definitely there. (Massive creaking turning into uneven lots, etc.)
I will post anything of interest that hasn't come up before in the CR threads. FYI to everyone: ROCKAUTO has the upper and lower arms for relatively cheap ($55-$100 each. )
You can get the bushings and the arm and install them in one shot. Might be worth some people's time (time>>>$$$), but I will reuse the old ones. Cheers!
Attached Thumbnails Energy suspension compression rod bushings-screen-shot-2011-05-20-10.34.21-pm.jpg
Old May 23, 2011 | 12:51 PM
FenixL1P's Avatar
I think nissan needs more stout lower strut mount bushings since they're starting sag... might as well go urethane, why not? the strut is absorbing the impact anyway so harshness shouldn't be an issue.
Old May 24, 2011 | 06:42 PM
vinco's Avatar
I love my ES Compression Rod bushings! I loved them so much that I ordered 25 cars worth of extra sets of them! PM me if you'd like to purchase a set.
Old May 30, 2011 | 12:31 PM
CTz33's Avatar
this is what i have on my 350z, its pretty solid better than OEM. Car handles good!!!..specially no NOISE issue!!!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
