Akebono BBK question: Please help!
Old May 27, 2011 | 02:11 PM
goodmank's Avatar
I have been searching like crazy and I have only found a very tiny amount of information regarding the Akebono BBK fitting with the 18" OEM wheels.
The only thread to even discuss the matter was this thread:
https://g35driver.com/forums/v36-bra...t-oem-18s.html
However, in the thread the 18" OEM wheels are from a sedan with a staggered 18x7.5 Front and 18x8.5 Rear setup. My 18" OEM wheels are from a 2006 coupe which I have tried to find the wheel widths and am pretty certain are all 18x8 Front and Rear.
If anyone else can please chime in and let me know if it would be possible to run the Akebono BBK with the 18" OEM wheels using 25mm spacers I would greatly appreciate it.
Last case scenario I will just have to remove the wheels and try the template, but I do not have access to a garage and tools right now so I would have to pay a shop to do so. Thank you in advance to anyone who can help me clear up this question!!
Old May 28, 2011 | 11:56 AM
amandab's Avatar
Bumpity bump bump
Old May 28, 2011 | 12:10 PM
nghiars's Avatar
the coupe 18's clear the brembos so they have more room than the sedan 18s. I dont see it wouldnt fit with spacers.
Old May 28, 2011 | 12:12 PM
nghiars's Avatar
post # 12 in the thread you provided has this template from CZP that you could use to test fit it. That'll be your best bet to find out!
http://www.conceptzperformance.com/i...akeoutline.pdf
Old May 29, 2011 | 11:28 AM
goodmank's Avatar
Yeah, that's what I am thinking as well. I think with a 25mm spacer I shouldn't have any issues.
Unfortunately, I am going to have to pay someone to do this since I don't have access to any tools right now but I will probably end up doing so to gaurantee I don't run into any problems.
Old May 29, 2011 | 11:33 AM
STCLAIRWEST's Avatar
The fronts dont clear.....The caliper is too big, I know this for a fact because I bought coupe 18s and ended getting stuck with them.
Rears clear for sure
Old May 29, 2011 | 11:37 AM
goodmank's Avatar
Crappy! Did you run a 25mm spacer with it? Just curious. May have to get the OEM 19's then.
Old May 29, 2011 | 11:39 AM
Nah I didnt, the face of the rim cleared. The caliper at the bottom was hitting the barrel of the rim.
Old May 29, 2011 | 11:41 AM
goodmank's Avatar
I am thinking with a 25mm spacer though that pushes the entire wheel out I should have enough clearance. This is only temporary until I get the wheels I really want.
Old May 29, 2011 | 11:48 AM
goodmank's Avatar
And thank you for the helpful info my friend
Old May 30, 2011 | 09:50 AM
soundmike's Avatar
I contacted two other members at that time who tried the coupe 18s, both confirmed it wouldn't fit without spacers. IIRC, at least one tried it with a 25mm, which they say cleared. Sadly i no longer have my PMs from that time.
Old May 30, 2011 | 10:25 AM
goodmank's Avatar
Fantastic! I will definitely make sure to get 25mm spacers then. Thank you very much for the information!
Hope to have both the spacers and BBK on in a month.
Old Jun 3, 2011 | 04:40 PM
Herbbie Hablib's Avatar
Just bought the G37S setup from the guy that sells them here, i asked him if they would clear he said they would, I have the 06 Sedan 18's.
Old Jun 7, 2011 | 02:47 PM
goodmank's Avatar
^^^Def let me know after you get them installed. I already ordered 2 sets of 25mm spacers. Would be great to not have to use them, but I have them just in case.
Old Jul 21, 2011 | 02:28 PM
Just saved myself the bs, picked up some OEM 19's. I have a feeling they wont fit and im not a fan of spacers
seagrasser
May 3, 2022 09:43 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
w4kj4k
Other Cars
Mar 6, 2016 08:06 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
