DIY SPC Rear Camber & Toe Kit Install
Old Oct 30, 2011 | 10:55 PM
G35Buzz's Avatar
^^^^^ thank you....
Old Oct 31, 2011 | 01:21 AM
Silver tiburon's Avatar
Originally Posted by g35man04
NO OEM Camber arm has adjustability bud.....you couldnt have those installed on your car when you bought it but no OEM Camber arm is adjustable. I can confirm that from NISSAN. I have been under every single year model.
also no OEM Camber arms has adjustable pivot ***** either. I can confirm that as I have replaced many bushings on our cars as well.
OEM Camber arm on ever model from 03-07 coupe or sedan.
I stand corrected. I just assumed these were stock, as they were on the car when I purchased it with STOCK suspension. Why these would be added on by themselves I'm not sure. Thanks for the pic of the actual OEM parts.
Old Nov 2, 2011 | 03:00 PM
alxmlr789's Avatar
Silver tiburon, do you still have that stencil I could borrow? I have the toe bolts, but no stencil. Let me know if you could mail it to me. I'll return it after I use it, promise!
Old Nov 2, 2011 | 03:24 PM
Yeah I still have it. PM me your addy and I'll throw it in the mail.
Old Nov 2, 2011 | 05:11 PM
P10 WRC's Avatar
okay, so the stock arms themselves don't have adjustment, but what about the bolt that holds them down. When i was installing my toe bolts, it looked like the camber bolts where adjustable too. can anyone confirm?
Old Nov 2, 2011 | 05:16 PM
TruGame's Avatar
ok im very new at lowering, ive seen your pic of your G lowered and it looks great so i need a camber kit and toe kit to lower my G the right way??
Old Nov 2, 2011 | 06:57 PM
The bolts that hold the camber arms in place do not allow for any adjustment, the simply hold the camber arms in place. The only adjustment is on the camber arms themselves. Hope that helps.
I will say from my personal experience the simple answer is yes. Although this is subject to debate, altering your suspension in any way will in almost all cases cause abnormal tire wear. This was the case in my situation lowered just under 1.5 inches. My tire wear was horrible because of the negative camber caused by my lowered suspension. It is months later after installing the camber kits and I am seeing drastic improvement in tire wear, as well as ride quality. If you are interested in the various opinions regarding this see: https://g35driver.com/forums/g35-cou...amber-kit.html
If not, I would suggest installing a quality made camber kit front and rear and call it a day.
Old Nov 4, 2011 | 07:39 AM
aloooha's Avatar
pmed you about the car wiggling. lol
Old Nov 17, 2011 | 04:34 PM
1YoungOwner's Avatar
Good DIY, this weekend hopefully I'll get around to it but many are using SPC cambers what you guys think about Ichiba rear cambers?
Old Nov 17, 2011 | 04:43 PM
whoozyadaddy7's Avatar
Ichiba rear camber arms are awful. Learned the hard way.
Old Nov 17, 2011 | 04:53 PM
Adil_G35's Avatar
put it in the DIY section?
Old Nov 20, 2011 | 08:48 PM
68_GT's Avatar
I just put in SPC camber arms and new rear H&R springs. Took maybe an hour including jacking the car up and pulling the tires off etc..
anyway I didnt do the toe bolts yet because I want my new springs to settle for a week or so before I go get alignment.
my question is..is there anyway the camber arms could have changed my toe, or maybe even by changing my springs somehow ????? by looking at it all put back together it looks like the rear tires now point inward ?????
Old Nov 22, 2011 | 01:12 PM
P10 WRC's Avatar
Not to argue or anything but that inner bolt holding the arm in place is CLEARLY adjustable just like the toe bolts. check out the eccentric bolt in this pic.
Old Jan 1, 2012 | 03:41 AM
You are definitely right P10 WRC, this bolt can be adjusted. What I meant however, was it doesn't need to be under the circumstances, and performs only as an attachment bolt with the aftermarket arms. Just to clarify, the inner cam bolt used to hold the camber arms in place can be adjusted, but the adjustment sleeve on the aftermarket arm makes this unnecessary. The inner camber bolt was intended to be used with the factor camber arm, which in itself can not be adjusted like the aftermarket arms can. My point being, It's not that the inner camber bolt can't be adjusted, It's that adjusting it is pointless given you now have just installed an aftermarket arm to provide that same camber adjustment instead. The only reason I could see needing this adjustment in addition to what is already provided by the aftermarket arms, is if you maxed out your adjustment sleeves and still required more camber adjustment. In this case, you would make a combined adjustment using the sleeves and the stock camber bolt together. That would be a pretty extreme case though, and probably unlikely.
Old Jan 24, 2012 | 12:03 PM
  #30
hdsupercrewf150's Avatar
Silver tiburon why did you replace your what looks to be TC Sportline Camber arms with the SPC? I just picked up a set before seeing your thread.
