Bilstein PSS10 or HKS III or Tein CS for comfort?
Old Oct 10, 2011 | 06:08 AM
ClutchBurner04's Avatar
Hey,
Just wondering if anybody has run through any of these or has them could give me their input on ride comfort and quality?
I'm looking for a little drop but don't want to sacrifice too much ride comfort. I know that I will have a little rougher ride with 20s but a drop is needed....and doing it right with coilovers seems to be the best option. Just read through the stickies, so these are what I came up with. I don't know about the BC coilovers either, but considering them.
Any other coilovers for a little drop and good ride quality? Any help would be great!
Thanks!
Old Oct 10, 2011 | 06:35 AM
BAUSauto's Avatar
what model g35 do you have now (sport or nonsport)
Old Oct 10, 2011 | 06:48 AM
Blue Dream's Avatar
I drove ttrank's car solo
You might want to poke around in here, but my suggestion would be the Tanabe Pro5s. I have them and comfort was #1 criteria in purchasing coils and these have not disappointed one bit. Numerous Driver members have ridden in my car and will verify my claim.
https://g35driver.com/forums/brakes-...ew-thread.html
Old Oct 10, 2011 | 07:11 AM
@ Auto Design: I've got an 04 Coupe with Brembo Brakes
@ Blue Dream: lol I've seen you around praising those coilovers ahaha. I'll look into those coilovers, I'm basically basing these "comfortable" coilovers on price now. I've seen that sticky actually, it's what helped me get to this point. Thanks!
Old Oct 10, 2011 | 07:19 AM
Blue Dream's Avatar
The Tanabe's will be significantly less than the 3 you posted. I paid less than $1200 shipped from one of our Vendors.
Old Oct 10, 2011 | 07:27 AM
Just reading reviews on the Tanabe's right now by other car owners, and it seems they all agree it's a steal at the price and the comfort that the coilovers offer. You are right sir.
Old Oct 10, 2011 | 07:44 AM
BAUSauto's Avatar
coming from a 03 Sport Basics/Tanabe/Megan basically the standard 10/8 rate will be the same level of comfort. Tad stiffer but all the same IMO. The Tanabe's are wonderful coils BTW I've known members with tanabes on their Gs for years now without a problem.
- Eric
Old Oct 10, 2011 | 10:09 PM
- Eric
I wasn't sure if you were referring to the Tanabe Pro 5s when you were comparing the three coilovers with 10/8 spring rates, but I'm assuming you are because the Pro 5's do have that spring rate. So, what you're saying is that the Tein Basics, and Megan will have comparable ride comfort to the Pro 5s?
I've heard that Tein Basics were horrible, and I just know the Megan coilovers are cheap but I've yet to read on them some more.
Thanks!
Old Oct 10, 2011 | 10:37 PM
BAUSauto's Avatar
I was speaking in terms of ride quality only in comparison to what you have now (stock).
TEINs are horrible mainly because of their horrible reputation of 'sqeeking' or going bad in the rear >.< Also you do not get damper adjustments with TEIN.
Megan are 'cheaper' but have always been a good choice for us.Tanabe pro 5s are also a great choice in coilovers. BCracing is another great choice.
- Eric
Old Oct 11, 2011 | 02:17 AM
Gsedan35's Avatar
Looking at the shock dyno's that I have for the Bilstien and Tanabe Pro5. The Bilstein has simular valving at full soft. Couple that with the Bilsteins softer spring rates and it will have a better ride quality. BUT, should you ever begin to turn up the damping, the Bilstien goes wrong. It changes things you don't want changed and doesn't change what you DO want changed. Granted, past half way the Tanabe's compression damping get's ubsurdly high. At can at least turn them up half way and get good control. Not so with the Bilstein product.
Bottom line. Bilstein will ride better if kept at full soft vs any setting you can set the Tanabe's too. But, you'd have to keep them at that setting. Which isn't for everyone.
Old Oct 11, 2011 | 02:21 AM
Gsedan35's Avatar
I tested the Megan product. Horrible at all settings. Too much spring in the front and awfull valving. Only reason I did not put them in the dumpster was becasue I bought softer front springs and tested them again. It was the only way I could honesty resell them vs going stright into the trash can.
Old Oct 12, 2011 | 05:42 AM
- Eric
Alright, thanks for clarifying. I definitely don't want squeeking or rattling. Been reading about BC coilover rattling too lol. Godd....so much more research to do.
Old Oct 12, 2011 | 05:44 AM
Thanks for the heads up. The prices for Bilstein are pretty high anyway.
Megan that bad huh? Well, I guess "you get what you pay for" comes into play here.
Old Oct 12, 2011 | 08:54 AM
Blue Dream's Avatar
First of all I want to say I'm in no way affiliated for Tanabe.
That being said don't beat your head up against the wall. I went through the same process as you are and literally spent 6 months researching. PM b2autodesigns for a price on the Tanabes and pull the trigger. There isn't a better set of coils out there that are comfortable for the price. Blows away BC, Megan, and all the other "budget" coils. You'll be relieved you don't have to spend more hours wading through reviews and changing your mind over and over. That way they'll be on the way and on your car sooner than you can say lickety split.
If you want another opinion PM ThatOneDude, he just put them on a coupe and is very happy with them as well.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
