While I'm at work, FIgure I could ask
Old Oct 24, 2011 | 10:46 PM
ThatOneDude's Avatar
without being flamed for "not searching". Honestly, there are a billion search results; I have no idea what my issue could be, so...
All I know is I just replaced my OEM camber links with adjustable SPL camber links. No toe bolts installed yet. Now my alignment is way off, and I no likey. Before I pay big bucks for repeated alignments (I want to just get one after I get my front camber parts, which have not been ordered yet), any idea what could be throwing my alignment off? All I did was the rear camber links. Adjusted them to the same length as OEM, and put'em on. Everything went well. Yet... off.
busy, gotta do ****, no time. tips advice etc plz Thank you!!alkj ;ajerlgjkva;r
Old Oct 24, 2011 | 10:54 PM
chink-ah-saur's Avatar
Did you have the bolt disk the same way but any time you mess with suspension you must get it alignment
Old Oct 24, 2011 | 11:34 PM
Yeh, I've heard that a billion times, but was wondering if there is anything I can do for now... I've swapped suspension on/off a few times without any problems. Wondering what exactly it is about the camber links that threw my suspension way off. I want to assume the bolt disk is the washer type thing that went on the inner side of the links... I'll re-check those asap. Thanks for that tip! If no luck, then... I guess if that's all there is to it, to get a professional alignment, then alright.
Thanks again!
btw how can I join your team. Sounds like a whole lot of fun~
Old Oct 24, 2011 | 11:41 PM
Yea that washer gives a litttle ajustment.
Your in, its so fun yull never leave
Old Oct 24, 2011 | 11:42 PM
And yyour oe toe bolt could moved a little that's all I can think of
4DGS's Avatar
Did you measure them up to your OEM arms?
Camber arms work by literally pushing the lower contorl arms away from or into the car. If you installed them at max negative camber or max positive camber then you will have drastically adjusted the camber just by installing them.
Old Oct 24, 2011 | 11:46 PM
All I know is I just replaced my OEM camber links with adjustable SPL camber links. No toe bolts installed yet. Now my alignment is way off, and I no likey. Before I pay big bucks for repeated alignments (I want to just get one after I get my front camber parts, which have not been ordered yet), any idea what could be throwing my alignment off? All I did was the rear camber links. Adjusted them to the same length as OEM/, and put'em on. Everything went well. Yet... off.
Sheeit man open ya eyes bic
Jk
Old Oct 25, 2011 | 12:58 AM
I love you. All is well now Steering feels perfect as far as I can tell. I will get a proper professional alignment once I get the rest of my suspension on, but for now, I am happy. Thanks a ton *****! I mean... A sore? wait...
Old Oct 25, 2011 | 03:17 AM
mikhaelbt189's Avatar
why dont get lifetime alignment on firestone?? with that u can go back anytime u want.
Old Oct 25, 2011 | 06:43 AM
Blue Dream's Avatar
I drove ttrank's car solo
Any time you adjust camber it affects your toe. If you don't have the bigger toe bolts then you can either get the camber in spec or the toe, but not both. Quit being a puzzy, spend the $40 on the toe bolts, and your issue will be solved.
Luv ya, mean it no homo of course.
And ***** your sig cracks me up, don't really understand why my name seems to be popping up in sigs lately, but I'll take it as a compliment.
Old Oct 25, 2011 | 09:44 AM
Firestones "Lifetime Warranty" will allow me to do that? I have a feeling there will be some terms and conditions that will make me less than satisfied.
I do have the toe bolts, I just haven't installed them yet. I don't feel comfortable doing it after seeing the DIY... I mean, one slip up and I cut too much with the dremel, then I'm screwed! oh no! I think I will let professionals handle that one...
Old Oct 25, 2011 | 10:56 PM
I love you too.
rezendvous420
May 31, 2020 01:26 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
newg37
Jul 26, 2015 09:32 AM
