Bed in process for HAWK pads....FYI
Old Mar 4, 2012 | 10:11 AM
gary c's Avatar
Bed in process for HAWK pads is easy and fun, when you're finished your pads will be very hot so don't panic if you see smoke....Make three runs 35 MPH to 10 MPH applying the brakes but never come to a complete stop. Now do two runs 45 MPH to 10 MPH applying the brakes and you still haven't come to a stop. Third run is from 65 MPH back to10 MPH applying the brakes once more for the last run. Now park your ride for a couple hours and let everything cool down. You're finished, those HAWK pads should always be quiet and work perfectly for miles to come with 90% less dust than OE pads! The bed in process makes your brakes 30% to 40% more effective which means shorter stopping distances....Gary
Old Mar 6, 2012 | 09:14 PM
VMRWheels's Avatar
Good info.
I just read about this earlier today actually, along with other brake pads.
Old Mar 6, 2012 | 09:43 PM
DKano's Avatar
Thanks! I saw you mention the bed in process in another thread but didn't really know what the process was like. Appreciate it!
Old Mar 6, 2012 | 09:59 PM
Invalid_User's Avatar
great info
Old Mar 13, 2012 | 07:58 PM
Arn35's Avatar
Thats what I did after installing them too, and it was fun.
Anyone have issue in the rain? If it is raining and the roads are wet it takes about 2 scary seconds before the brakes grab. Did not have that with the OEM's. So now I pre-brake to dry them before I have to exit.
Replaced rotors with slotted at the sametime as pads.
Old Mar 13, 2012 | 08:57 PM
nghiars's Avatar
this should be a sticky in your brain if you ever do your own brake jobs.
Old Mar 13, 2012 | 10:14 PM
gary c's Avatar
Even if you don't do your own work, you can do the bed in process on the way home from the shop....Gary
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
vamarris
Sep 26, 2015 12:56 PM
Cbohannan101
Sep 12, 2015 10:32 PM
