Can't reattach compression rod after installing ES bushings
Old Mar 22, 2012 | 11:27 PM
DivZero's Avatar
I just can't get the rod low enough to screw in the ball joint to the hub. I have the other end attached btw. I have tried pushing down on the rod and jacking up the hub. I also tried to lift the hub up more by Unbolting the sway bar link and damper. HOW DO I GET THE ROD BACK ON? Thank you.
Old Mar 26, 2012 | 12:28 PM
DivZero's Avatar
I got it by loosely attaching the outer compression rod to the knuckle. Then I used a jack to push up the inner rod onto the large stud. I placed the jack just next to the bushing and had to move it around a little as I went along to get the bushing to slide in properly.
MyfistYourFace
Aug 8, 2015 11:58 AM
kinetek
Aug 3, 2015 04:25 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
LoSt180
Jul 15, 2015 08:31 AM
