Coilovers or springs?
Old Apr 8, 2012 | 02:10 PM
saason.Ez's Avatar
If i want to drop my car 1.5 inches why should i go the coilover way that so many of my friends are recommending me to do.. instead of dropping it 1.5 inches with springs? Trying to make a big purchase this week and need to make a decision
Old Apr 8, 2012 | 02:12 PM
aa2033's Avatar
if you can afford it, go coil overs.
There are many more advantages of coil overs than just the drop. I did springs, and then coil overs, and now when I look back I wish i had of saved my time and money and done coils instead of wasting time on springs.
Old Apr 8, 2012 | 02:27 PM
saason.Ez's Avatar
such advantages are ?
Old Apr 8, 2012 | 02:41 PM
Adil_G35's Avatar
with coilovers you can fully adjust your suspension(depending on what kind of coilovers you get most are adjustable). Main thing to point out is you get better control and handling from coilovers. Majority of people don't see much of the difference until they go from lowering springs to coilovers. I try to tell people to skip the whole lowering springs phase. I guarantee that if you buy springs you'll be satisfied for a few weeks or months. But then it will hit you...just you wait and see. Save up some more and get coilovers. Lowering springs are for noobs.
Old Apr 8, 2012 | 02:46 PM
Adil_G35's Avatar
theres more to suspension than just a drop. If you buy springs you'll learn the hard way. But if ALL you want is just a 1.5' drop and nothing more or less than go for springs. You don't need those advantages from coilovers if you want only a SPECIFIC drop.
rdavis's Avatar
Coil overs last longer and better ride
Old Apr 8, 2012 | 02:47 PM
Adil_G35's Avatar
when you say better ride i hope you mean more fun to drive and not comfort lol
Old Apr 8, 2012 | 04:14 PM
herrschaft's Avatar
The main advantage will be the increased life span of the suspension components. If you drop 1.5" on stock struts, those struts aren't going to last very long. Then you come to the point where you need to decide whether you want to replace with OEM struts, aftermarket struts or coilovers. Unless you install everything yourself, the labor cost will begin to add up when you do individual components at different times. Better off doing it right the first time.
Most coilovers offer multiple adjustments regarding ride height/damper stiffness and are fairly easy to work with.
Old Apr 8, 2012 | 06:31 PM
g35pillow's Avatar
Do coilovers!!!
Old May 6, 2012 | 07:06 PM
Big Booty Trudy's Avatar
Do coilovers last longer the stiffer you set them? Or vise versa
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
