View Poll Results: What do the masses recommend?
SPL
12
46.15%
SPC
13
50.00%
Ichiba
3.85%
Stillen
0%
Eibach
0%
Voters: 26. You may not vote on this poll
Poll on Front Camber Kits
Old Apr 17, 2012 | 03:57 PM
Extreme Dimensions's Avatar
I've been a part of this community for about 9 years, 1 year with this account and 9 years with my personal account. I am getting annoyed of having to replace my tires every 2-3 months because of camber wear. Even though Flaken takes care of us, its just a hassle, now to get to the point. I want to know what you guys are rolling with and if you would recommend it. After using the "Search" option, as I am sure someone will want to mention in this thread, I noticed the main three front camber kits are SPL, SPC and Ichiba. Would love to have the SPL's but damn $700?? Don't hear much about Stillen or Eibach. What's all this ruckus about the arms breaking off if you bottom out? From what I've heard SPC fixed that problem, is there still an issue with other kits? Either way, would love to here some feedback.
Note: I have an 04 G35 Coupe with 20" DPE Variant R07s and an HKS LS+ Coilover set up.
Old Apr 17, 2012 | 04:12 PM
herrschaft's Avatar
From my research SPL is the best, and not all kits will adjust for + camber. I've got SPC which for the most part have worked fine, my front is slightly out of spec since the shims and my BBK don't work well together.
Old Apr 17, 2012 | 04:20 PM
Ya I've heard great things about SPL, but $700 for a front upper camber kit is just not in my budget as of now. I bought tires literally two months ago and they are completely done in the front. Are the revised SPC kits recommended? I've heard a lot of mix reviews.
Old Apr 17, 2012 | 04:34 PM
herrschaft's Avatar
The common issue I've seen people have the most is with the dash lighting up after everything is installed, due to people not installing the spacers on the wheel sensors when using the shims. And for those that are slammed the top of the A-arm will hit the fender/liner, but I'm not low enough to have that problem. Thats all I'm aware of
Old Apr 17, 2012 | 04:39 PM
CandlestickPark's Avatar
ill Sedan
If I ever get front camber arms (I don't need them my natural camber is perfect for my setup) I'll get SPLs.
SPCs are pretty good, but if you are really low they will make knocking noises.
Whatever you do please stay away from any and all Ichiba suspension parts:
https://g35driver.com/forums/brakes-...l-garbage.html
https://g35driver.com/forums/brakes-...ny-others.html
https://g35driver.com/forums/brakes-...killed-me.html
https://g35driver.com/forums/brakes-...-arms-ftl.html
Old Apr 17, 2012 | 05:01 PM
How slammed is slammed? Im not a part of the "Stance" movement, but I do like a clean drop, meaning no gap in between my tire and fender.
Thanks for those links brotha. I would like to know though, like I stated above how low would low be?
Old Apr 17, 2012 | 05:10 PM
Shanes_G's Avatar
i thought toe ate up tires not neg camber.
Old Apr 17, 2012 | 05:12 PM
I really don't know crap about tire wear or camber wear, but I thought the simple solution was getting a camber kit?
Old Apr 17, 2012 | 05:14 PM
Shanes_G's Avatar
did you ever get an alignment? i just have spc toe bolts and and alignment and my tire are just fine. and im droped about 2 inchs.
Old Apr 17, 2012 | 05:21 PM
Well I dropped my car less then 3 weeks ago, but haven't had a chance to get the alignment, don't toe bolts go on the rear arms? My front tires are the ones that went out. Then again I haven't gotten an alignment in a long time.
Old Apr 17, 2012 | 05:24 PM
Shanes_G's Avatar
no the toe bolts go in the spring bucket connecting it to the frame. and you should get an alignment a week or so after you lower your car after everything settles. your toe is prolly off big time.
Old Apr 17, 2012 | 05:26 PM
okay well my new tires are on order from Falken so once they get in I'll just shoot all that out at the same time.. i'll just have to keep an eye on my tires to see how they wear.
Old Apr 17, 2012 | 05:27 PM
Shanes_G's Avatar
yea let us know if it works out for you.
Old Apr 17, 2012 | 05:39 PM
Definitely thanks for your help!
Old Apr 17, 2012 | 07:55 PM
herrschaft's Avatar
My fenders are about flush with the top of the tires too so you should be good. I would get an alignment first and see what the specs are before buying anything.
When I was dropped on only Tien S-techs, I had an alignment done immediately afterwards and my front tires didn't last long so.... Some will say you don't need a camber kit and others will say different. From my experience I would recommend them.
