Slotted,drilled or slotted drilled rottors? whats better?
i just wanted to know which rotors were better. im not gonna be going to the track or race everyday but in case i need to stop hard for any reason i wanna make sure i have one the best to help me with that. and i came to the conclusion that slotted will be better for me since i wont be racing it so no need for me to the the drilled ones specially since they crack easier
Gary
I would vote for centric blanks and save $500 instead of that basically cosmetic upgrade.
If your primary goal is to be able to panic stop at any time, then the OEM setup sounds like what you want. The biggest issue in panic stopping is usually the driver not pressing on the brakes hard enough early enough.
The DBA 4000 is a great rotor, maybe a little overkill for the street as they are heat treated and slapped with thermal tape, if the car is only used for the street there is no harm in taking it down the DBA T2 Street Series, that will save you some extra money you can put somewhere else without giving up any performance.
Depended on your G these may not be available, but Centric offers their Powerslot rotors to compete with the DBA T2. Both are great rotors, both have the veins and hat painted to cut on rust.
There's no need to have a drilled rotor, they are only for looks and they cut the structural integrity of the rotor under heavy breaking.
-Nick
-Nick
