Alignment out of wack, Mechanic blames to much negative camber
Old Mar 2, 2013 | 02:28 PM
AyyRyy's Avatar
So I recently mounted my new wheels and I had to run -4.5 camber up front and -2 in the rear.
Everything is fine at low speeds but up to around 60 mph it gets really floaty and hard to handle.
I talked to the guy who did my alignment and he said that its because I'm running so much camber up front but I'm not sure if that's true or that he just didn't know what he was doing.
Anyone have suggestions?
Old Mar 2, 2013 | 03:13 PM
bigc's Avatar
Wings Nation
My suggestion is to adjust your camber so you're closer to OEM spec:
https://g35driver.com/forums/wheels-...ons-specs.html
Running that much camber is silly, but its even sillier to complain about ride quality if you do.
Old Mar 2, 2013 | 03:20 PM
AyyRyy's Avatar
Considering im running a 10.5 wheel with -6 offset that's about how close I'm getting.. trust me I wouldn't run it if i didn't have too. Ride quality isnt an issue its the fact that my car is dangerous at highway speeds.
Old Mar 2, 2013 | 03:22 PM
CandlestickPark's Avatar
ill Sedan
Why more camber up front compared to the rear? Can you post your alignment printout sheet?
Old Mar 2, 2013 | 03:23 PM
AyyRyy's Avatar
Dont have one :\ but the guy only set it to the lowest camber settings that would fit under the fenders.
Old Mar 2, 2013 | 03:29 PM
bigc's Avatar
Wings Nation
Have you thought about getting new wheels? Ones that fit without so much camber?
Old Mar 2, 2013 | 03:34 PM
AyyRyy's Avatar
The camber isn't an issue in terms of looks/wear/ride quality, I'm trying to figure out if its whats causing my car to handle weird. The only thing I can think of is that my toe is off
Old Mar 2, 2013 | 04:20 PM
Xet's Avatar
Xet
How are you at -4.5 in the front but only -2 in the rears???
Also what are the rest of your alignment specs? Toe?
Old Mar 3, 2013 | 01:22 AM
totopo's Avatar
I don't think it's the camber, or just the camber. Honestly -4.5 and -2 isn't that bad; that's probably about what bimmers like to have at the track.
What's your toe at? negative toe will make the car "darty" over bumps and track towards the bumps. Try for some positive toe, even at the expense of some camber. Maybe the alignment shop ended up with negative toe trying to get the camber as positive as possible?
A "floaty" feeling though would make me think of the shocks.
Or you could have bad bushings or bad bump steer.
Old Mar 3, 2013 | 09:03 AM
OBsessed's Avatar
Check how far off your caster is as well, if a combination of toe and caster are both out (but neither out badly individually) it can cause some odd feeling in the front end. Also take a look at your bushings, particularly the lower control bushings, they go bad without really knowing it and combined with the rest of the odd settings will contribute to uncertain feel while driving.
I'm running 19x10-4 up front with -3 camber and Toe in spec and have no problems. If you don't have adjustable A-arms (SPL, or at least SPC) get them. And pull your front fenders so you can dial back the camber and still have it fit the body well.
Old Mar 3, 2013 | 09:30 AM
gary c's Avatar
YES!
Thanks Chris, silly is a nice word or description when refering to the trendy camber settings some members think it's cool to run. Noticed this trend coming out of Japan in the mid '90s and hoped we were smart enough not to follow them.
Gary
Old Mar 5, 2013 | 08:38 PM
AyyRyy's Avatar
Hey guys sorry for the late reply but everythings fine.
Talked to the guy who's doing alot of my fitment work for me and he said that it was because the tires had to wear a little bit first.
Also I have a full spc camber kit front and back and the dumb *** who installed it didn't dremel the new hole for the toe bolt so i'm sure that came into play.
But it doesn't budge at all now, did about100 today and it felt solid.
seagrasser
May 3, 2022 09:43 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
migurus
Sep 5, 2015 09:39 PM
