mevotech vs dorman vs beck/arnley
Old Mar 24, 2013 | 10:34 AM
hrdwirk1's Avatar
im just trying to get some feedback on the manufacturers; which is better than the other etc. i have to replace several parts of the suspension and need your input/feedback.
Posted from G35driver.com App for Android
Old Mar 25, 2013 | 03:43 AM
bythabay's Avatar
I have been using Mevotech parts on a few cars lately and have been satisfied with the quality. I believe Beck A. tends to be the best of the bunch, whereas doorman tends to be the worst.
Just be careful ordering the pats and double check with the manufacturer to make sure the part you are ordering is correct for your application.
Old Mar 26, 2013 | 05:40 PM
hrdwirk1's Avatar
are the coupe compression rods interchangeable with the sedan? ive looked at have received conflicting answers. i cant seem to find the mevotech compression rods for the sedan.
Old Mar 26, 2013 | 05:46 PM
bythabay's Avatar
check on mevotech's site for the correct part number for your sedan, it's there.
Old Mar 26, 2013 | 06:02 PM
AuAltima3.5's Avatar
I am a big fan of keeping it OEM.
If I had to choose: beck
Dorman- no even on 15 yr old beater.
Old Mar 28, 2013 | 02:11 PM
hrdwirk1's Avatar
So I must be an idiot because I cant seem to find the part number on the mevotech website. I need #15 in the suspension diagram. Last night I was looking on ebay and I noticed that the same part for the coupe had the same number stamped on it as did some of the listings for the sedan. Is there anything to this?
The 2nd picture is of the compression rods for a coupe. I saw the same numbers stamped on some of the sedan listings but they are 3 times the amount (OEM only)
It seems impossible to find an aftermarket compression rod for the sedan.
Attached Thumbnails mevotech vs dorman vs beck/arnley-3840175.gif   mevotech vs dorman vs beck/arnley-coupe-comps.jpg
Old Apr 11, 2013 | 09:38 PM
cdn_guy's Avatar
Same problem - I cannot find compression rods for 2003 sedan anywhere on vendor catalogs and rockauto. It is displayed as for coupe.
Old Apr 12, 2013 | 11:43 AM
DEMoLITIoN's Avatar
My friend had the same problem, ended up getting the "coupe" arms off of rock auto and they fit his sedan.
Old Apr 12, 2013 | 12:01 PM
cdn_guy's Avatar
Cool, thanks...lots of threads here suggest they are not interchangeable
redpearl99
Dec 1, 2019 11:02 AM
WyattSoCalKent
Jul 13, 2015 09:55 PM
dookie
Jul 12, 2015 04:50 PM
Frankieg35
Jul 24, 2014 01:54 PM
