Replacing Compression Rod bushings
Old Apr 24, 2013 | 02:32 PM
lsxjunkie's Avatar
I am going to be replacing my compression rod bushings soon.
Going with Whiteline bushings. I have a 30 ton shop press so it should be fairly straight forward.
My car has 76000 miles on it. Would you guys go ahead and put new control arm bushings in as well? If so the only Whiteline ones I see are for Inner. Is that the only front lower control arm bushing that they sell?
Thanks
Old Apr 29, 2013 | 04:15 PM
DEMoLITIoN's Avatar
Is your car lowered? I would avoid poly compression rod bushings. They don't offer the flex they need to operate normally. The ball joints are not replaceable on the compression rode. A very good combo to go with is SPL Compression rod bushing, SPL Inner Control arm Bushing and Whiteline shock mount bushing. Pair that up with some adjustable end links and call it a day.
MyfistYourFace
Aug 8, 2015 11:58 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Jul 15, 2015 08:31 AM
