Small Questions Thread: Brakes and Suspension
Old 02-16-2014 | 12:21 AM
ohitstruee's Avatar
Originally Posted by LoSt180
07 Sedan brakes will NOT fit your 03 Sedan (directly). 05-06 Sedan and 05-07 Coupes were updated to 2-piston calipers and larger rotors, so those would be a good upgrade. The 07+ Sedan brake CAN fit if you use the Akebono brackets because the mounting ears are different for the V36 bodies. But if you go to the trouble of getting Akebono brackets, you might as well hold out for Akebono calipers. Tokico HP's are backordered with no known delivery date. A good OEM option these days would be KYB Excel-G (GR-2) shocks.
Thanks
  #92
Old 02-16-2014 | 04:32 PM
ohitstruee's Avatar
How can I tell what calipers I have any markings I should look for?
  #93
Old 02-17-2014 | 10:30 PM
DEMoLITIoN's Avatar
post a picture.
  #94
Old 02-19-2014 | 10:33 AM
brownie's Avatar
Where can I find decent priced drilled/slotted replacements for my 06 sedan 6mt/sport? Everything I see is all saying "standard models - excluding sport) & the place sent me a set before but they were just the regular set up so they didn't fit.
  #95
Old 02-19-2014 | 11:21 AM
LoSt180's Avatar
06 Sedan should have the same sized rotors as all 05-07 coupes and 05/06 sedans. There was no difference between sport and standard.
Unless you were looking up 03-04 parts (or 07+ sedan parts), then yes there's a difference between base and sport/Brembos.
You're looking for part number 120.42080 Front & 120.42088 Rear. They first three numbers will vary depending on the brand, drilled, slotted, etc.
You can verify here: http://centriccatalog.com/Inquiry/Ap...06&m=68&mm=885
  #96
Old 02-19-2014 | 01:07 PM
brownie's Avatar
Unless they sent me the wrong thing.. because they were smaller than the ones on my car now so I couldn't use them.. I'll look for 05-07 coupes though.
  #97
Old 02-19-2014 | 01:29 PM
LoSt180's Avatar
They must have sent you rotors for 03-04 base models, those were smaller than the 05 revisions.
  #98
Old 02-20-2014 | 09:32 PM
ohitstruee's Avatar
Originally Posted by DEMoLITIoN
post a picture.
Here's what I have
Small Questions Thread: Brakes and Suspension-image-758904762.jpg
Small Questions Thread: Brakes and Suspension-image-207849328.jpg
Small Questions Thread: Brakes and Suspension-image-1703510425.jpg
Small Questions Thread: Brakes and Suspension-image-3919230730.jpg
  #99
Old 02-21-2014 | 06:02 PM
DEMoLITIoN's Avatar
That is a 07+ Sedan caliper. This is a 05+ caliper (bolts on) You can see the difference in the spacing.
You will need this to fit the caliper: CLICK HERE
  #100
Old 02-21-2014 | 09:59 PM
ohitstruee's Avatar
Yes that is exactly what I ordered thanks for the help , ill keep u updated on how tge install goes
  #101
Old 03-06-2014 | 09:47 PM
ohitstruee's Avatar
Any pictures of that bracket installed
Having trouble bolting up the caliper bracket to the akebono bracket there a bolt on the akebono bracket that won't let me put the caliper bracket on
Having trouble bolting up my calipers to the akebono bracket the 07 caliper bracket gets in the way of a bolt on the akebono bracket for my 07 g35 journey brakes to my 03 g35 sedan
Any way around this??
  #102
Old 03-07-2014 | 11:11 AM
LoSt180's Avatar
Check this thread, has lots of pictures. Sounds like it has to be installed a certain way: https://g35driver.com/forums/brakes-...03-07-g-z.html
  #103
Old 03-07-2014 | 02:31 PM
ohitstruee's Avatar
The akebono bracket is different then what I have akebono has a curb mine don't has anyone done and has pictures of 07 brakes like the one I posted on 03 sedan
  #104
Old 03-12-2014 | 12:39 PM
DEMoLITIoN's Avatar
Can you post a picture of the bracket installed?
  #105
Old 03-24-2014 | 03:24 PM
vipster's Avatar
I shouldnt' be on here reading this bc I'm at work but I am needing rotors soon on my 03 sedan. I dont' want to go with plain rotors and I read here that the 2 piston G/Z front brake setup would be a nice upgrade. what model should I be looking for to get these parts off of? are the front rotors bigger than what I have on there, I'm assuming yeah but I just want to be assured. Thanks in advance.
Quick Reply: Small Questions Thread: Brakes and Suspension
