Creaking sound when i come to a complete stop
Old Jul 21, 2013 | 08:04 AM
ReggieRegg's Avatar
I just installed the 14" akebono BBK and my first problem was that the brakes felt super soft. After bleeding them again and again the proper way it finally felt normal. After 5-10 minutes of driving with them on i noticed a creaking sound when i would come to a complete stop or even when i took my foot off the brake pedal. Any idea what could cause this? The kit i bought was brand new with SS brake lines and stoptech drilled and slotted rotors. I had heard this sound before i upgraded to this kit whenever the brakes would get wet. Now i hear it on this new set when the brakes are dry. Any help is appreciated
Old Jul 21, 2013 | 10:56 AM
Urbanengineer's Avatar
It may be just because the pads need to warm up. What pads are you using?
Post a video with your noise. My new track brakes squeak like a chew toy when they are cold.
Old Jul 21, 2013 | 01:04 PM
ReggieRegg's Avatar
Im using the posi quiet ones that came with the kit. I ordered the one with ss lines brake fluid and the drilled rotors. I can try to post a vid a little later on
Old Jul 28, 2013 | 06:27 PM
Ogee's Avatar
I'm having the same problem with my Akebono BBK I just installed. When I drive I hear a rhythmic knocking/ scraping sound, and when I come to a complete stop there is a thumping noise. The pedal is not really soft but there is no real difference from when I had my OEM brakes.
Old Jul 28, 2013 | 07:05 PM
K.C's Avatar
K.C
I'm not sure about the creaking problem your having but I do have the posi quiet pads and after about 5000 mi I have a ton of squealing while applying the brakes and it's pretty annoying .... I ordered some stop tech pads and will be installing them this weekend . I'll keep yall updated on the wear of the old pads and the new ones . IMO I think its the pads that are causing the sound that your hearing .
Old Jul 28, 2013 | 11:59 PM
Ogee's Avatar
Yeah the more I've drove around today the less noise it makes. I think it was the pad rubbing against the rotor.
Old Jul 29, 2013 | 12:11 PM
DEMoLITIoN's Avatar
Make sure your lug nuts are tight!
Old Aug 15, 2013 | 10:11 PM
wallofgrath's Avatar
Probably the larger surface area of metal from bigger rotors and aftermarket pads... But maybe they just need to be "broken in"... try slamming on the brakes at high speeds a few times ... I always do that when something feels weird
Old Aug 15, 2013 | 10:16 PM
Ogee's Avatar
Yeah after about 100 miles of driving all noises ceased. I guess they just needed proper bedding in. Thanks for the advice!
Old Aug 21, 2013 | 12:11 AM
Stillen06coupe's Avatar
did you break them in the proper way? some pads come with directions on how to do it.... 5-10 moderate brakes from 45mph to almost a stop(not a complete stop, will imprint the rotor cuz of heat during break in)..... then 5-10 hard brakes from 60mph to almost a complete stop... it gets the 2 different metal compositions to imbed properly into eachother. if you do it right, they should be glowing red when done, sometimes they will even smoke, depends on the brand(pad material)
Old Aug 21, 2013 | 08:41 PM
Ogee's Avatar
I bought my calipers used and the OEM pads had a lot of life to go, so I thought that I would use them up before selling a kidney to buy new ones. I did not bed them in properly right away cause I was scared to go fast with all the noises the brakes were making. After I noticed the noises fading I followed someone's bedding in instructions on this forum tho. Thanks!
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
ScraggleRock
Aug 11, 2015 10:16 PM
kd03g99
Jul 30, 2015 11:24 AM
