TruHart Front Camber Kit
Old Nov 12, 2013 | 12:28 PM
Black04speed's Avatar
Hey guys I'm looking for a front camber kit for my 04 G35. I have it lowered slightly on 350z revised springs. I'm trying to correct my front camber that is about -1.4 camber on both sides in the front. I can't afford the SPC and I also don't want to really cheap out on these camber kits. I found a kit by a brand called TruHart and I can't seem to find any info on here about them. Is anyone running them? What do you guys think? I'm just looking for something to correct my uneven tire wear.
www.amazon.com/gp/aw/d/B00C8SUT76?pc_redir=1
Old Nov 12, 2013 | 06:49 PM
JKL1031's Avatar
your in spec. I wudnt spend that much money to remove .4 degrees of camber. unless your tires wear, but they should not.
Old Nov 12, 2013 | 06:57 PM
Hey thanks for the reply. I'm at -1.4 not -.4. I was recommended a camber kit since the front won't align to specs.
Old Nov 12, 2013 | 07:19 PM
JKL1031's Avatar
I know but if I could choose I would set camber at -1. The manual says 0 to -1.25 for the front, but check how nominal is -1.25 on the rear, and our cars weight is near 50/50. I wouldnt spend the money on arms to remove so little camber. Just give it some time n check the wear later.
Old Nov 12, 2013 | 07:31 PM
Thanks man. It's been about 10k and the tires And I'm starting to worry because I can already see the tires wearing unevenly and they are getting very loud.
Old Nov 12, 2013 | 07:39 PM
JKL1031's Avatar
hhmmm. Im only at 4k with -1.5 and 2. u mind sharing pix?
Old Nov 13, 2013 | 04:03 PM
Far back of tire
Old Nov 13, 2013 | 05:19 PM
JKL1031's Avatar
10k total miles? Maybe u do need plates.
Old Nov 14, 2013 | 12:58 PM
Yes I do. I need someone's input on this camber kit. Has anyone tried it?
Old Nov 15, 2013 | 12:50 PM
Adrenaline's Avatar
I tried rear kit so far so good for now. Next week going to buy for front. Quality much better than a cheap kits.
Old Nov 16, 2013 | 05:15 PM
How many miles do you have in the rears now? How are they holding up?
Old Nov 18, 2013 | 04:52 PM
t12i867's Avatar
I was looking at the truehart on ebay lastnight for the rear. I was wondering the same thing too...if there good or not. Mite just be another ebay brand tho.
Old Nov 18, 2013 | 10:47 PM
Adrenaline's Avatar
I have only 1500 miles on it. Didn't check alignment numbers yet.
Old Nov 18, 2013 | 10:50 PM
Adrenaline's Avatar
I bought from the original site
jsimonk
Dec 22, 2023 03:49 PM
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
