Rear axle clicking noise HELP!!!
Old Feb 18, 2014 | 06:38 AM
jonathan852's Avatar
Exclamation Rear axle clicking noise HELP!!! WITH VIDEO
Hi guys,
I just got my 04 g35 coupe a month ago and found that theres squeaking noise comes from the rear axle. is it the control arm bushing worn out? plz help!
Thanks!
Sounds more obvious at 0:02-0:05
Old Feb 18, 2014 | 06:48 AM
ScraggleRock's Avatar
I can't hear what your talking about thru the other noise, but does it continuously make the noise, or is it just when you take off?
Old Feb 18, 2014 | 07:25 AM
it continuously making the noise when you are on bumpy road.
it is more like something is rusting and making squeaking noise. I am not sure
Old Feb 18, 2014 | 02:55 PM
Oh ok, I hear it now. Like a squeeky wagon wheel. As they say, the sqeeky wheel gets the grease. Can you tell what side its coming from?
Old Feb 18, 2014 | 03:27 PM
S 854's Avatar
Search on Driver for 'rear axle' and you'll see dozens of existing threads like
https://g35driver.com/forums/g35-cou...xle-click.html
https://g35driver.com/forums/g35-cou...tsb-210-a.html
https://g35driver.com/forums/g35-cou...ase-reply.html
https://g35driver.com/forums/tsb-tec...all-2004s.html
Also can sign up & search on infinitihelp.com for the related TSB (technical service bulletin) pdf for this:
ITB05-002b -REVISED-
2003–2005 G35 SEDAN AND COUPE; CLICKING NOISE FROM REAR AXLES
rezendvous420
May 31, 2020 01:26 PM
ScraggleRock
Aug 11, 2015 10:16 PM
wuppiedog
Aug 7, 2015 11:16 AM
atk08
Jul 30, 2015 03:12 PM
papo020
Jul 17, 2015 10:30 PM
