Why do my Brembo's suck?!?
#61
#66
front brake → Left rear brake → Right front brake
BTW, this could be the longest brake bleed thread ever!
#67
Two things not mentioned.
1) You did mount the calipers so the bleed screws are on top vs bottom right?
2) You could have air in your ABS system. Not likely but at this point....
Brake pads matter but given the same pad, one on brembos and larger rotors vs oem 2 piston calipers on smaller rotors, the brembo package will increase braking force and thus should result in a shorter brake distance (given the tires are up to the task)
G35fromPA (08-12-2015)
#70
