04 Coupe Rear upper control arm ball joint nut not moving - using 800 lb-ft air gun
Old May 27, 2018 | 03:22 PM
axerickson's Avatar
I'm trying to replace my rear upper control arm on an 04 coupe. The ball joint nut on both sides isn't moving even with a good sized air gun pounding on it. The cotter pin is out. There is no rust or corrosion that I can see.
This nut has never been removed, so it's been in place for 18 years. The original torque on this is only 62 lb-ft. All the other bolts in the suspension have moved without a problem.
Any ideas how to get this nut to move?
Old May 27, 2018 | 03:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
PB Blaster and a breaker bar. Make sure you're using a 6 point socket so you don't round off the edges with a 12pt.
Spitfire91104
May 28, 2016 10:28 PM
Shawno72
Steering & Suspension
Oct 7, 2015 11:10 PM
Slime
Mar 22, 2013 03:17 AM
orl-g
Florida G Club
16
Mar 28, 2011 03:05 AM
dchen007
May 2, 2006 05:52 PM
