Check valve location?
Old Dec 26, 2019 | 10:39 AM
Abdul Kelani's Avatar
G35 coupe
is there supposed to be a check valve in this hose?
booster to engine vacuum hose
Old Dec 26, 2019 | 11:19 PM
coffeysm's Avatar
It's on the hose from the booster going into the plenum.
Old Dec 26, 2019 | 11:20 PM
G35 coupe
so it is supposed to be inside, I have a hollow hose. :/
Old Dec 27, 2019 | 12:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It should be pushed up inside the hose, it's not an external piece. Squeeze the rubber and verify its not in there, new hoses don't come with one so typically you dissect the old hose to remove the existing check valve.
If you're is missing it's a common over-the-counter part.
smitty89
Feb 6, 2013 09:50 AM
DaveB
19
Jul 25, 2011 12:09 AM
Klubbheads
Nov 29, 2007 06:58 PM
bendu
Mar 11, 2007 11:02 PM
D87
Jan 31, 2006 10:14 PM
