Hello new here I have 05 g coupe I didn’t drive the car much so I chose to drive it to work today I was on the highway and when I touched my brake pedal slip vdc abs came on I pulled into a local auto parts store got the codes read was c1142 guy told me brake switch bought swapped it out still nothing I checked my stop lamp fuse blown blew the fuse immediately could someone point me in the right direction of where I should look next
@braydin125 Did you figure out the issue??? This happened to me three nights ago but not while on the road. I was going to move my car out of the driveway when I noticed I couldn't shift out of park, then noticed all three lights (ABS/SLIP/VDC OFF) were on. I have a happy switch on the car, and I thought that I had accidentally flipped it, but that was not the case. I checked for my brake lights to come on when I pressed the brake and they did not activate. So I started checking the fuses, and sure enough, the brake light fuse was blown. Installed a spare and it blew it again, although I can't recall if I stepped on the brake before it blew it or not. Anyway, I disconnected the battery for about 30 minutes, installed another fuse and the dash lights went out and brake lights lit up. Parked the car on the street, just in case it happened again in the morning before going to work, that way I could take my wife's van to work. Low and behold, when leaving for work, everything worked fine. But, when I was getting to work, all three dash lights lit up. Made it to the parking lot, and after parking, tried to shift out of park and no luck. After work, I used the shift lock release button to shift and drive home. Checked all fluid levels and took all four wheels off to check for any leaks and didn't find any obvious issues. Ended up replacing the brake switch that night and the dash lights went out and everything worked fine. Everything worked fine yesterday to and from work. This morning as I was about to leave home, all three dash lights came back on, no brake lights and could not switch out of park. Had to use the shift lock release button to make it to work and now here I am, looking for answers. I see you posted recently, so I'm hoping someone sees this and can provide some answers. I'm planning on flushing the brake fluid, since it's been a while since the last time I did it. Also, when it happened the second time, I did check for codes and got ABS code C1142 Brake Fluid Pressure Sensor Circuit. I did some research and found that sometimes that code pops up when the brake switch is malfunctioning, which is what led me to replace it. Anyway, I'll keep searching for answers online, but hopefully someone here can help out. Thanks to all in advance. Oh, by the way, my G is a 2003 Coupe Base, 314+K miles, in case that may be of assistance to figure ou the answer.
