Sway Bar Summary!
I ordered my Stillens. Hopefully I'll be able to have them installed and I can have a bit of fun before the snow falls here in the Great White North!
BTW, does 350EVO still offer the bars. No longer on their site from what I can see. Attempts at contacting them have proven futile, and they haven't e-mailed me back after a week. I'm not impressed.
Put on my Hotchkis sways this weekend. After some deliberation, I think I'm gonna go ahead and order some McMasters collars. I found it interesting that they offer the collars in quite a few different materials too. Steel, Zinc-Plated Steel, Chrome-Plated Steel, Stainless Steel, and Aluminum.
~What would hold up better to corrosion, between Chrome-Plated Steel & Aluminum?
~Where's the cheapest place to get them? Would it be just directly from their website then?
Aluminum would not have corrosion problems and would be lighter than steel. Of the other ones, the best corrosion resistance is chrome-plated > stainless (but if they salt the roads it could get corroded) > zinc-plated (galvanized) > plain/mild steel
Originally Posted by Triple8Sol
Are you sure? I would think it would go in the order of: Stainless Steel > Chrome Plated > Aluminum > Zinc Plated > Steel ?
Aluminum is corrosion resistant because it forms an oxide coating on the surface, effectively sealing it. pitting on the surface of any of these materials, ie, due to rocks hitting them, can accelerate corrosion. I would still go w/ the AL ones because of reduced weight. You don't even need those big collars actually. You could probably get away with using heavy-duty worm-drive tube clamps or something similar.
Money well spent, for peace of mind. Since I AutoX and plan to track the car, I
Looks like the most cost-effective option for McMaster's collars that would resist corrosion, would be Aluminum #6436K141 for the front, and Chrome-Plated Steel #3370K33 for the rear. That's what I went with. $30.12 + s/h.
I spoke with an Infiniti service tech today and he said they have seen high mileage G's with Stillen sways that have worn mount brackets (I'm not sure exactly what area he was referring to) - he said the OEM are beefier now because of the number being replaced. I'm not referring to the bushing bracket, something on the ends that are mounted on the sides. Does anyone know what this is (or experienced being worn and replaced)?
The endlinks. I'll prob order up some '05+ endlinks...
-Mark
Originally Posted by mr_ecktid
Bumping for info on this too, my G has almost 76k miles and I am contemplating getting the Stillen Sways, is the tech reffering to the rubber bushings?
-Mark
-Mark
I just got off the phone with DaveO discussing this... I'm going to pick up replacements in a couple of weeks (I don’t have any real issues now, but figured might as well replace before it's an issue - since apparently there is a history).
