Stock Brembos SQUEAK like hell: any remedies?
Old Aug 15, 2005 | 08:28 PM
NRG 35's Avatar
i've noticed that the brembo brakes that i have on an 03 g35 tend to squeak a lot... and also leave tons of brake dust. is this normal? has anyone found a quick or easy solution to this nagging problem? thanks in advance~!!!
Old Aug 16, 2005 | 02:00 AM
imalazeeass's Avatar
yup, hawk brake pads. Also u can checkout project mu pads.
Old Aug 16, 2005 | 04:57 AM
NRG 35's Avatar
so bascially the pads are what's causing the squeaking noise? i'll definetly look into that.. thanks!
Old Aug 16, 2005 | 05:42 AM
yea its the pads that squeek and give hella brake dust. I believe hawk still squeeks a little but the brake dust is reduced drastically.
Old Aug 16, 2005 | 06:42 AM
Balzz's Avatar
I'll trade you with my '05 calipers; problem solved.
Old Aug 16, 2005 | 01:06 PM
P_Diddy's Avatar
Hose down your brakes. Dirty brakes squeak. Also, maybe your pads are worn down and warning indicator is scraping.
Old Aug 16, 2005 | 09:04 PM
ipse dixit's Avatar
Change your pads (i.e. get new ones) and then properly bed them.
Old Aug 16, 2005 | 09:28 PM
redwillow's Avatar
20 Year Member
properly bed them.
that is the root cause of squeaking, make sure you bed them properly. Try to keep them clean dust will lead to squeaks too.
Old Aug 17, 2005 | 12:28 AM
G35Papa's Avatar
I'll ask for myself and others who also don't know but are afraid to ask.
"bed them properly"? Can one of you please explain this process for us that are not as mechanically knowledgable.
Thanks in advance.
Old Aug 19, 2005 | 03:03 AM
http://stoptech.com/whitepapers/bedincontents.htm
Old Aug 19, 2005 | 06:49 AM
Triple8Sol's Avatar
The noise sounds like pads that aren't making full contact. Check them out...
Old Aug 19, 2005 | 06:19 PM
G35Papa's Avatar
Originally Posted by imalazeeass
Shweet! Thanks
Old Aug 19, 2005 | 06:50 PM
MikeyMike's Avatar
Rollin On Dubz
Can't you warp your brakes if you spray water on them while they are hot?
Old Aug 19, 2005 | 07:49 PM
LjN_728's Avatar
Give that man a cigar! That's why it's not recommended to wash your car after a nice drive. Not only would you risk your brakes warping, but your rotors cracking.
snic09
Nov 8, 2017 01:46 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
Roddy914
Aug 31, 2015 07:07 PM
