ken's current suspension settings.
Old Oct 21, 2005 | 04:16 PM
kenchan's Avatar
Here's my latest suspension settings. use at your own risk. you're welcome
to copy it exactly. i don't care.
Goal: to achieve best cornering characteristics on dry roads while maintaining the low-ride dressup looks & comfort. Straightline stability is top notch. car feels luxurious but not floaty, nimble confident handling, not much body roll.
Car is fun to drive, oversteer on demand, but not tail happy.
SETUP FRONT:
Total toe (degrees): 0.10
Camber: -1.8 each side
Springs: TEIN S-Techs for G35C (lowered 1.2")
Damper: D-Specs 3 from firm
Swaybar: Stillen (softest setting)
Tires: 245/35/19 Potenza S03 (on 8.5" wheels) // 36.5psi
Wheel Offset: +23 mm
SETUP REAR:
Total toe (degrees): 0.28
Camber -2.6 each side
Springs: Eibach Prokit for G35C (lowered 1.4")
Damper: D-Specs 4 from firm
Swaybar: Stillen (firmest setting)
Tires: 275/35/19 Potenza S03 (on 10" wheels) // 36.5psi
Wheel Offset: +36mm
Ambient temp today: 65F
I must say i am very pleased with this setup right now.
more info on my car, hit the link... also updated my comments on Modification Tips on the site too, for your coffee break.
Last edited by kenchan; Oct 24, 2005 at 02:10 PM. Reason: updated setting final touch (front D-Specs), added offsets.
Old Oct 21, 2005 | 04:31 PM
636Racer's Avatar
This would be a good sticky and a good thread to help people baseline themselves if they have similar setups.
moderators???
Old Oct 21, 2005 | 04:36 PM
ScottR's Avatar
^ +1 I'll say it again, Ken is the man when it comes to setting up the G!
Old Oct 21, 2005 | 05:19 PM
808HerbzG35's Avatar
Wow, good post. Subscribe.
Old Oct 21, 2005 | 05:38 PM
636Racer's Avatar
Have you ever thought about toe adjustments? Is there kits out there tha can adjust toe degree? I'd like to some how adjust for front toe-out and rear toe-in for track days.
Old Oct 24, 2005 | 02:07 PM
kenchan's Avatar
636- The alignment shop can adjust toe on your factory setup. The rear might not toe-in enough for your race setting if your neg camber is severe.
I stepped back 0.25 on the front D-Specs and i think it feels better than
2.75 from firm (now 3 from firm). The turn-in was a little on the under
steer side until the rear swaybar kicked in and the transition was a little
too abrupt.
Forgot to post my offsets so updating the original post.
Old Oct 24, 2005 | 06:14 PM
636Racer's Avatar
Thanks for the precaution. I dont think I'll be too aggresive with the toe and camber adjustments.
Old Nov 6, 2005 | 06:59 PM
kenchan's Avatar
bump...here you go those that were asking about this thread
Old Nov 6, 2005 | 10:15 PM
Teeter's Avatar
SETUP FRONT:
SETUP REAR:
Wheel Offset: +36mm
Ken, continuing my education..........why so much negative camber in back? Also, what does "total toe" mean. I understand toe-in and toe-out but am not familiar with the total toe term. -T
Old Nov 6, 2005 | 11:55 PM
kenchan's Avatar
teeter- i tried -1.3, -1.8, -2.6, -3.1 and -2.6 has the most margin before
the sudden tail break the car's character has while the tires don't break
from sudden straight line acceleration. any thing less, i could not get on
the throttle fast enough through the turn. if i get a hold of the adjustable
front endlinks and do soft/med hole setup, i might be able to lessen the rear
by +0.4..but on this car I will probably be -2 or more.
toe of right + toe of left = total toe
Old Nov 7, 2005 | 01:33 AM
Deang35c6's Avatar
Serious camber, bro. I purposely tuned out my camber to gain more traction from dig. my current settings are -1.2 front and -1.5 rear.
Old Nov 7, 2005 | 01:42 PM
kenchan's Avatar
yep, if im setting up the car to drag race, I would use a different setting too.
Old Nov 8, 2005 | 04:48 PM
Deang35c6's Avatar
I always wanted to compare our suspensions. It seems we did two different things, but with the same outcome almost. I'm running harder springs 386/402, dampened softer with the D-specs (4.75/4.5) and running 18s with 245/275. It would be great to see exactly which mod (tires, shocks, springs) have had the greatest effect.
Old Nov 9, 2005 | 01:36 AM
kenchan's Avatar
swaybars
Old Nov 9, 2005 | 12:01 PM
Deang35c6's Avatar
No sways yet. Probably in the spring. I can actually feel that my suspension is performing better than the stock sways. Body lean in the corners is reduced, but I think it's the shocks/springs doing most of the work. All my camber/radius rods and arms have polyurethane bushings, so I can feel the rubber on the sways ends along with its softer settings is the weak link.
