broken end link, need help asap!
Old Dec 8, 2005 | 12:53 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^^ that's the thread I remember...
still the ? is it true
Old Dec 8, 2005 | 01:33 PM
Gsedan35's Avatar
Originally Posted by geeitup
This from the Motorsports forum
timm
My rear sway bar links got noisy after 10,000 miles or so, the stock replacements are cheap ($13.00 each) and have beefier joints than the originals. I guess Infiniti knew they were a weak link.
Triple8Sol
Frankly, I'm surprised that none of these aftermarket sway bar kits include new endlinks. So you're saying the stock Infiniti replacement endlinks are better than the stock endlinks that came with the car? I'm confused...
timm
Yup, must have been updated for '05 but they're definitely bigger ball joints than the originals.
Ok that has me curious so I just went out into my garage, I used a dial caliper and measured a old 03 front end link and a revised end link on the car. Both ball joint head's measured the same 25mm and 30mm across. Just to say it, this is another one of those things where it would be a good thing for me to be wrong, but I can't come up with that thus far. Perhaps it's time to visit my dealer's part's department for a printout.
Old Dec 8, 2005 | 03:14 PM
kenchan's Avatar
thanks for the info. that was the front that broke on you?
what stiffness settings do you use again?
I should probably just get a pair of the stock endlinks and keep it in my
garage, huh? I don't foresee my fronts breaking, but the rear will
probably fail sooner or later.
Originally Posted by Gsedan35
I carefully examined the differances between my oem 03 end links and the revised end links I replaced them with. Nothing was their for me to say they were any more robust then the parts that came off, though who's to say Nissan didn't improve manufactuering processes, I dunno. The bolt's that went into the sway bar end's were a few mm longer. Given that my oem end links failed at about 24K, I don't think they will be the last set I have to buy. I just wish that the Nismo part's were a lot less costly. Though I'd hate to have a set of those to fail in the same way as the oem parts.
rezendvous420
May 31, 2020 01:26 PM
wuppiedog
Aug 7, 2015 11:16 AM
atk08
Jul 30, 2015 03:12 PM
cyrus32
Jul 18, 2015 06:22 PM
