Stoptech BBK + Spare tire
Old May 8, 2006 | 08:47 AM
  #31
k_hojnacki's Avatar
Hey just throwing this out there but why couldn't you just get a large spacer and stick it in the spare wheel? Is it the issue that the donut rim is just too small or an offset issue? It seems that with a spacer, you could clear the calipur if that is the real issue. I was planning on going BBK soon myself so I am very interested in any responses.
Old May 8, 2006 | 11:51 AM
  #32
ma_sha1's Avatar
spare
Originally Posted by cato
MA SHA1,
What 17X7 wheels are you talking about that fit the Wilwood BBK? As you know, I have the 2003 stock 17s that do not fit the Wilwood BBK, I was thinking the least expensive way to getting the Wilwoods would be to buy some new wheels that fit.
Roja formular 7, 17x7. I don't know what off-set. I am guessing 45?You can see part of the wheel in this photo. It's forged one piece, weight 15lbs. I got a killer deal on ebay, actually made money by selling OEM 17x7 & get these on ebay. I am not sure they are still available on ebay.
There are quite a bit of room actually, might even fit 14" BBK. I do have 22mm spacer on with my BBK.
There are more room on this wheel than my 18x8 Piaa Super Rozza 50 offset.
Both spoke & rim clearance. Strange. Probably the wheel is designed to clear BBK?
Old May 8, 2006 | 02:45 PM
  #33
cato's Avatar
SouthernComfort Moderator
Oh man... Those are the wheels I want. You didn't need a spacer to fit the BBK?
Old May 8, 2006 | 02:56 PM
  #34
codeflux's Avatar
interesting point about using the spacer. could be something worth at least testing.
i might pull one of my wheels off, to see exactly what doesn't fit and where the problem rears its ugly head. hm. that sure is a good suggesion.
thinking out-loud... the doughnut should be quite a bit thinner than the regular wheel... by using a spacer, one should still have enough of a thread left, so the lug nuts secure the doughnut safely. now, i know what you're thinking - using a spacer increases the sheer forces on the wheel bolts - but then again, i would not expect someone who's driving on a doughnut to take corners at high speeds, or go above 60 on a highway, or do anything else stupid.
so, this is probably something worth figuring out.
Old May 9, 2006 | 11:22 AM
  #35
ma_sha1's Avatar
spare
My spacer is Kics 20mm Adaptor type, bolted on the hub & new bolts
is attached with the spacer. So I did not ty to fit it without a spacer.
I am guessing 10-15mm spacer might be needed, but if you order wheels with the correct low offset, you may not need it.
Old May 12, 2006 | 09:18 PM
  #36
destroid's Avatar
Question:
The 17" spare will fit over any stock rear brakes (incl the rear brembos) and probably some of the small rear BBK like the Stop-Tech 328mm ST22 setup - correct?
If you get a flat on a front tire couldn't you just move a good rear wheel to the front and put the spare on the rear where it should still fit?
The tire size is different but a short low-speed drive to a station should be ok and not mess up the LSD.
Of course folks with sick 13 and 14 inch 4 wheel BBK kits are still in trouble...
Old May 12, 2006 | 10:23 PM
  #37
amg35's Avatar
Florida G35 Club
Originally Posted by destroid
Question:
Great point. If I just get the front BBK, I could swap the wheels for a temporary fix. Thanks.
Old May 13, 2006 | 05:53 AM
  #38
codeflux's Avatar
won't work for me, since i have 19x9.5 wheels in the back.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
D1dphresh
Aug 7, 2015 06:10 PM
ohitstruee
Aug 7, 2015 04:59 PM
wuppiedog
Aug 7, 2015 11:16 AM
