Sentra SE-R brake question?
Old Jan 14, 2006 | 09:50 PM
deadmanincbh's Avatar
I read that the Sentra SE-R is using Brembo brakes. Now I would like to know first is that true and second if it is true will the brakes fit a G35 sedan with the sports package with out a problem? Thank you.
Old Jan 14, 2006 | 11:31 PM
g35doc's Avatar
They only have brembo fronts with tiny rotors.
Old Jan 15, 2006 | 01:16 AM
Oh, because I read that the front come with 12in brembos and 10.6 in the rear. I was thinking about getting the calipers off them and use either Brembo or some other reputable roaters along with them.
Old Jan 15, 2006 | 02:11 PM
STill_matic's Avatar
You can call Nissan and check the part numbers. They'll be the same regardless.
Example= STi brembos have the same part numbers as the g35 brembos.
Old Jan 15, 2006 | 03:34 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Are you sure about that? The Sti brembos have about a 12.5 cm distance between the mounting bolts, the G35 ones is 10 cm. Sti pistons are 40/46, G35 is 38/44. Front rotor Sti is 326*30, G35 is 324*30mm. Sti's brake line going from rear pistons to front is external, G35's is internal. They have the same gold paint though.
Old Jan 15, 2006 | 04:07 PM
So I am not sure will the Sentra Brembo calipers work? What about the STI or Evo calipers could those work also?
Old Jan 15, 2006 | 08:06 PM
I cant get Sentra brembo calipers for 200 bucks for the front pair but I don't know if they are any good and if they will fit.
Old Jan 16, 2006 | 11:16 AM
E_K's Avatar
E_K
The Evo or Sti calipers will NOT work unless you get fancy and get a custom bracket made, and then you'll be using a larger rotor as well.
I just recently designed and had made a pair of brackets for a project of my own. Total was about $300 using T6061 aluminum.
Not sure about the sentra ones.
Old Jan 16, 2006 | 10:10 PM
Do you mean the total cost of install was $300? Damn, anyone know what others might work with out the cost of extra mods?
Old Jan 17, 2006 | 03:17 PM
MOTOP's Avatar
Sentra SE-R Brembo brakes are 4-lug. I'm not sure if calipers will fit over 5-lug Brembo rotors that come with G35/350Z Brembos
Old Jan 17, 2006 | 07:10 PM
Well I have an 03 sedan so I don't know how many lugs that is.
Old Jan 17, 2006 | 10:04 PM
E_K's Avatar
E_K
You guys are confusing things.
Rotors on sentra is 4 -lug. You wouldn't be using the rotors anyway.
Caliper is what you're interested in. What I was saying about the $300, is that I had a pair of brake caliper brackets made recently that cost $300. The calipers themselves are another story. This is just for the brackets.
Old Jan 18, 2006 | 01:43 AM
Oh, so how would I go about checking to see if the caliper will fit or not with out purchasing the item? Thank you?
jsimonk
Dec 22, 2023 03:49 PM
miata007
Aug 17, 2015 04:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
