TEIN Type CS Damper vs Tein Type Flex
Old Jan 24, 2006 | 05:11 PM
mkn1620's Avatar
same with title, which one is better and how is it better? can someone help me with that please!
P.S. is Tein H-Tech the same with those?
Old Jan 24, 2006 | 07:32 PM
GReddySetGO's Avatar
H. Tech and S. Tech are just springs only.
CS and FLEX are full coilovers. They both are 16-level damping force adjustable and they are both EDFC compatible.
The diffrence is the valving in them. The CS model is much more comfortable. It keeps a good comfort level, but is adjustable to be stiffer for track/race use. It's a lot better than stock or any springs(S. Tech or H. Tech).
Also the spring rates on FLEX as stiffer than CS.
FLEX is "better" in terms of performance. FLEX will give you better feel on the track. However FLEX will be too stiff for some users for daily driving. It is NOT comfortable like stock or CS.
Old Jan 25, 2006 | 12:01 AM
Beta99's Avatar
Tein Flex (twin tube construction, adjustable dampners
Full-length adjustment and height adjustment for separate setting of the height and spring preload
Spring rates 672/672
Stiffer then oem by F+114% R+98
Transfers +16% roll stiffness to front
Side Note: Extremely high spring rates mean even when the adjustable damping is set as low as possible, you may not find ride quality happiness, several reports of this setups harshness exist Yet a few owner comment’s of a “like stock ride quality” also exist. However given the fact that they use a spring stiffness that’s over 100% stiffer then oem, if ride quality is of concern, either hitch a ride in a car equipped with them or make a different choice. In addition, several review’s have been done by people actually having the original more softly sprung Tein Flex coilovers do not take their comments to mean the same as the one using the current product, the original product specs are listed below under Tein Flex JDM.
Tein CS (Monotube constructionad, adjustable dampners )
Special Note: A comfort ride system compare to HKS LS.They are valved and sprung to fulfill their intended mission of offering up improved ride comfort. More specifically their valving will impact the performance they can deliver. And to add, revalving them is extremely expensive if you find they are too soft for you. If you want performance, pick a different Tein offering or pick a different brand.
Spring rates 392/392
Stiffer then oem by F+25% R15%
Transfers +10% roll stiffness to front
The Flex with a higher spring rate would be stiffer than the CS, more track oriented.
Old Jan 25, 2006 | 02:09 PM
mkn1620's Avatar
so, for the comfortable and smooth. CS will be the one to go?
Old Jan 25, 2006 | 03:00 PM
Yes.
Old Jan 27, 2006 | 07:51 PM
mkn1620's Avatar
kewl, thx alot
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
