05 6mt Coupe Just Dropped! Need ADVICE on Camber Results
Old Mar 1, 2006 | 02:28 AM
GSTG35's Avatar
Hello all...I just dropped my 05 Coupe and wondering to see if theres anything you can suggest on making my cambers get back to within specs. Im using the TEIN Basics with the SPC Rear Camber Kit and below are the results I got. Everything else is stock including the OEM 19 inch rims. My questions are:
1. Are my front cambers pretty bad? If so any reccomendations?
2. Has anyone on this site used the ACP 350Z/G35 Adjustable Front Camber Arms listed at this link:
http://www.autocarparts.com/part/1488/1
3. The alignment shop said that my control arm bushings were cracked and said I should get some Polyurethane bushings. How important is this and any brands you can recommend?
Any help would be appreciated.
Thanks.
D
Front Left
Actual Before Specified Range
-1.6/ -1.5/ -1.3 to 0.3 CAMBER
8.8/ 8.8/ 7.3 to 8.8 CASTER
0.07/ -0.12/ 0 to 0.08 TOE
15.5 inches RIDE HEIGHT
Front Right
-2.8/ -2.8/ -1.3 to 0.3 CAMBER
9/ 9/ 7.8 to 8.8 CASTER
0.07/ -0.1/ 0 to 0.08 TOE
15.3 inches RIDE HEIGHT
Rear Left
-1.4 /-1.6/ -1.8 to -0.8 CAMBER
0.13 /0.81/ 0 to 0.22 TOE
13.3 inches RIDE HEIGHT
Rear Right
-2.1 /-2.1/ -1.8 to -0.8 CAMBER
0.14 /1.16/ 0 to 0.22 TOE
13.4 inches RIDE HEIGHT
Last edited by GSTG35; Mar 1, 2006 at 02:35 AM. Reason: To make results more clear
Old Mar 1, 2006 | 04:09 AM
haze's Avatar
your front cambers seems to be imbalance betwen the left and right. Is this after alignment?
It's weird to see your right side having so much more negative camber than the left.
Old Mar 1, 2006 | 08:36 AM
kenchan's Avatar
-2.8 front is too much unless you're racing or something and specifically need that much front lateral grip.
the rears L/R is too far apart too. should be within 0.2 degrees. the toe looks ok.
Old Mar 1, 2006 | 10:16 AM
GSTG35's Avatar
Can you reccomend any Front Camber Kits other than the Stillen ones? Is my cambers being off due to an alignment shop problem or is the car just too low and out of whack?
Old Mar 1, 2006 | 10:17 AM
GSTG35's Avatar
yes this is after an alignment.
Old Mar 1, 2006 | 10:37 AM
haze's Avatar
i think it has to do with the alignment shop, at least the left and right should be more equally negative. Is the right side signififcantly lower than the left?
Old Mar 1, 2006 | 10:59 AM
Q45tech's Avatar
Is this with you sitting behind the wheel............makes a difference as your weight will lower left side...........after all the driving conditions must be maintained to preset the static misalignment
Old Mar 1, 2006 | 12:45 PM
kenchan's Avatar
^^ but it won't drop THAT much unless you're like over 300lbs or something.
we had a discussion about corner balance long time ago and was determined that the balance of the car mandates more than just driver weight.
sure the weight of the driver will tilt the car a tad, but not -1.6 vs -2.8
Old Mar 1, 2006 | 04:16 PM
GSTG35's Avatar
I appreciate all the help...I do have one last question...
looking at the ride height:
Left Rear: 13.3 inches
Right Rear: 13.4 inches
Left Front: 15.5 inches
Right Front: 15.3 inches
Should it be the other way around? Meaning the front lower and the back higher? Is it going to make a difference?
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
driftsucky
Jul 15, 2015 12:38 PM
