Do I need to replace my shocks?
Old Mar 7, 2006 | 02:07 PM
Derek173's Avatar
For the past month my car has started to squeak on bumpy roads. Thinking it was a bushing I checked and lubed them all and still squeaking. So here is a description of the problem.
after the car has been sitting for a while, lets say overnight. I will not hear the squeaking for a few minutes of driving but once it starts it doesnt go away. So one day I pull into the garage right after I just started to hear the squeak so I start to shake the car and I hear it loud and clear coming form the front of the car. If I get out of the car and start to shake it I will hear the squeak but if the car is parked for a minute of two it cant be replicated anymore.
03 G35c, 60k miles, Daily Driver with track days Stock suspension
Old Mar 7, 2006 | 02:44 PM
nnkfws333's Avatar
How is the ride quality? If it rides normal then no. If you push the front of the car down a few times and let go, if it bounces like crazy then they are blown but if not then Im sure you are fine.
Which bushing did you lube? On 240sx's its the bushings for the tension rods are worn and cracked. It could be many things...
Old Mar 7, 2006 | 04:29 PM
Derek173's Avatar
thanks, I am not sure what it could be? Shock mounts?? The car does not bounce and feels fine, just squeaking
Old Mar 7, 2006 | 06:34 PM
Derek173's Avatar
I SWEAR GUYS, After 5 minutes of driving it begins and if you park it right a way and start to shake the car you can hear it. After a minute of being parked I am not able to reproduce it, it goes away after the car is settled??
snic09
Nov 8, 2017 01:46 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
smartin0924
Aug 13, 2015 07:29 PM
si_driver
Aug 11, 2015 07:08 AM
cyrus32
Jul 18, 2015 06:22 PM
