350z tein h techs
Old Mar 23, 2006 | 01:10 AM
Gpair's Avatar
350z tein h techs
How much wil these lower a G? It says 1" for the Z, is it the same with the G? Where's the best place to get a hook up on them?
Old Mar 23, 2006 | 02:52 AM
dklau33's Avatar
The Tein H Techs for the Z do not say 1" drop for the Z. It is 0.3/0.2 inches F/R.
http://www.tein.com/htech.html
Old Mar 23, 2006 | 09:20 AM
Sponger's Avatar
6MT Brembo Coupe
Mine dropped .75/.50, front/rear
Old Mar 23, 2006 | 09:26 AM
eledin's Avatar
This is what I have being installed shortly too, but now I'm wondering is that kind of drop even noticeable?
Old Mar 23, 2006 | 09:48 AM
Sponger's Avatar
6MT Brembo Coupe
There is a noticeable difference in height although I wish the back was a little lower.
Old Mar 23, 2006 | 10:13 AM
pdjafari's Avatar
i love the drop...perfect and can still make it over 'some' speed bumps/driveways..
Old Mar 23, 2006 | 10:37 AM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
I just purchased the 350Z H-Techs over the 350Z RS*R Ti2000. I thought the drop would be too much for Maryland roads with the RS*R's. Anyone with the 350Z H-Techs running 19x10.5 +22 in the rear and if so, any problems. Anyone with any camber issues? All seaches say no. Thanks.
Old Mar 23, 2006 | 02:48 PM
Gpair's Avatar
Whoa sorry man. The site I pulled from says this:
http://www.zcarparts.com/store/merch...y_Code=PSDC01E
They will lower your 350Z approximately 1 inch from stock ride height....
Hence the 1" that I stated.
Either way, I'd rather not have a full inch anyways. I dont want to have to drive around things and go too slow over them. Im not abou the whole "too low teenage thing" anymore.
Old Mar 23, 2006 | 04:30 PM
DRG35R's Avatar
20 Year Member
The website is wrong. If you search on this site you will find that the 350Z H-Techs lower the Z .3F and .2R. That translates into .8F and .7R for the Coupe. The website you found is making a generalization of the average drop acheived on a car using this spring, not specifically the 350Z. I just purchased this spring for my coupe based upon the info I researched from this site and the fact I had these on my old sedan as well. I think if you do a search you will find this is the spring of choice for many G owners, both coupe and sedan.
Old Mar 24, 2006 | 02:37 AM
Gpair's Avatar
Cool, thanks for the info. I did look around and searched a bit as well. I dont want a real low stance. Just wanted to bring it down a slight bit.
How is the camber after the springs??
Old Mar 24, 2006 | 09:39 AM
Sponger's Avatar
6MT Brembo Coupe
You should be able to get it aligned within spec.
Old Mar 31, 2006 | 10:41 PM
OC 350GTCoupe's Avatar
Exactly, front is a perfect two fingers in between the fender and the wheel. The back is still like 3 fingers.
I just got em installed today. Will they settle any? Will 350Z D Spec shocks make it any lower? (i doubt it does)
Old Mar 31, 2006 | 10:48 PM
Sponger's Avatar
6MT Brembo Coupe
Mine haven't settled any more since the install and I doubt your's will since they're quality springs.
KruZZe
Feb 27, 2023 05:04 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
