Another G sedan with 350z suspension *PIX*
Old Sep 7, 2014 | 11:22 PM
  #406
kpowe1's Avatar
@gaugedgc nice
Finally got all the pieces to my suspension setup this weekend by taking a short drive down to Z1. I'm doing my suspension tomorrow with the Z setup, Kyb shocks and replace the front and rear control arms and compression rod bushings with energy suspension bushings. Then I'm putting on a set of rays and I'm done.
Attached Thumbnails Another G sedan with 350z suspension *PIX*-car-parts.jpeg   Another G sedan with 350z suspension *PIX*-zi-motorsports.jpeg
Old Feb 10, 2015 | 11:27 PM
  #407
Durenbergerg's Avatar
Originally Posted by g35guy86
yeah im planning on getting the nismo/aero kit in the summer. For the people who have had the kit put on, is it pretty easy to do yourself? because i dont feel like going to the dealer to get it installed.
hey man random question but where did you buy your decklid spoiler?
Old Mar 3, 2015 | 02:25 AM
  #408
dustynhugee's Avatar
I know this thread is getting dragged the hell out, but hey quick question, I have a 06' x, I want to get the 350Z springs. Which year Z will fit my G if any, if so will the stock OEM springs work well with it, or just get the matching springs, or cop a nice set of Tokicos?
Old Mar 25, 2015 | 11:46 AM
  #409
robbiedigital's Avatar
2 questions:
1) Can you bring your car into alignment lowering on full 350z suspension without any additional kits? I hear the rule of thumb is 1", so if I had to guess, I'd say no, but just checking.
2) Are spacers a good idea with this setup? If so, how much?
Old Mar 25, 2015 | 02:00 PM
  #410
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by robbiedigital
2 questions:
1) Not quite (just barely) though it will go into the slightly more aggressive specs for the 350Z
2) Sure, why not? Stock Wheels?
Old May 3, 2015 | 07:01 PM
  #411
redGlorenzo's Avatar
I feel like the color is off on these springs, suppose to be 350z springs, real or fake?
Old Jun 7, 2015 | 11:35 AM
  #412
Mr.23Zone's Avatar
Somebody please help me I'm so confused! I have a 03 Sedan non sport. Just picked up some 19" staggered rays and ran across some coupe eibach pro kit springs for real cheap. Would this be a bad idea? To low? If it will work the. What else should I purchase? If it wont work then what is your guys opinion on what would be my best option with my set up? Revised unrevised and numbers?!?! Idk what this means, I'm def a newbie
Old Sep 13, 2016 | 08:45 AM
  #413
warenzer's Avatar
Originally Posted by TechFarmer
Here is a picture comparing the rear spring heights. The G35 coupe spring is about 1/2" shorter than the sedan. The 350Z spring is just a little more than 1/2" shorter than the Sedan spring.
350Z (revised) -- G35 coupe -- G35 Sedan (sports suspensn)
350Z's rear spring length 312mm
G35 coupe rear spring length 320mm
350z's exactly 8mm shorter than g35c
Old Sep 13, 2016 | 08:49 AM
  #414
warenzer's Avatar
real height
350Z's rear spring height 312mm
G35 coupe rear spring height 320mm
Old Sep 13, 2016 | 08:52 AM
  #415
warenzer's Avatar
Old Sep 19, 2016 | 02:17 PM
  #416
eloke's Avatar
2008 g35xs here. Head is throbbing a bit from the overwhelming amount of knowledge folks are sharing. I'm on a line for a set of 2003 Z springs and struts. Just the fronts.
Question is: slap the whole assembly in and go, or....? Then follow with standard G coupe rear springs... or?
Thanks fellow G owners. :-)
Old Sep 24, 2016 | 08:31 AM
  #417
Blue Dream's Avatar
I drove ttrank's car solo
Wrong sub-forum bud
Post here: https://g35driver.com/forums/g35-sedan-v36-2007-08-217/
Old Sep 24, 2016 | 09:33 AM
  #418
eloke's Avatar
Sorry. Still a total NOOB yet :-)
Old Apr 4, 2017 | 02:39 AM
  #419
Spankin's Avatar
Any seen these springs before??
Bilstein shocks - F4-BE5-6869-TO
Blue dots with one goldish/brown
Hey, got these off a 350z 2004 and it seems they are aftermarket but I have no clue if they are any good for my 2002 sedan with sports suspension?
Heres the shocks that came with the springs that would help identify the spring rate of the springs but I can't find any info on either!
Anyone got an idea if they will be ok.
Old Jun 5, 2019 | 06:03 AM
  #420
Jpas31's Avatar
G35X
Originally Posted by Hammerhead i-Eagle Thrust
am i the only one who thinks rear coupe springs looks the same as rear z srpings
full z
vs
for the front end did you use just the spring or swap the whole strut out also for the front did you use revised or unrevised 350z springs, and what year rear g springs or struts or both did you use
