"Z" Htechs?
Old Mar 31, 2006 | 08:54 AM
wnt1bd's Avatar
"Z" Htechs?
Ok I am confused now, I have an 05 6mt and I want to drop the carabout an inch. I was going to buy the Htechs until a friend of mine told me the springs rates are softer then stock. I want to go lower, but I don't want a softer ride.
Is there any truth to this, and if so what to get short of coilovers?
Thanks for any help.
Old Mar 31, 2006 | 09:27 AM
yacoub's Avatar
Check the sticky at the top of this forum section:
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375
Stiffer then oem springs by F+14% R+11% (see note at very top)
Transfers +3% roll stiffness to front
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
Stiffer or softer then oem springs by F+ 5% R-22% (see note at very top)
Transfers +27% roll stiffness to front
Looks like the Z H-Techs are the way to go.
andresito7
Aug 1, 2015 04:53 AM
xjohnnyleex
Aug 15, 2007 01:08 AM
Jee_35
Archived Sales
Oct 3, 2006 09:01 AM
dmtx
Sep 15, 2005 06:43 PM
