Tanabe Springs
Old Apr 6, 2006 | 01:27 AM
Psycraft's Avatar
Tanabe Springs
ok so im gonna get the tanabe springs the drop is pretty serious its 1.7 in the front and 1.3 in the back,im wondering if this is gonna make my car camber bad,also..im on oem 18's,anyhelp please this is the first car i will have dropped and its gonna happen on monday...
Old Apr 6, 2006 | 03:55 AM
aleok's Avatar
i'm also gonna do the same. so far everyone has told me that i'll need aftermarket camber kits. idk if we'll need for the front or just the rear. i'm also wondering if we need aftermarket toe arms. i would advise getting shocks also, unless you just wanna wait until your stock ones blow, (and risk messing ur whole suspension up)
Old Apr 6, 2006 | 12:42 PM
Psycraft's Avatar
what shocks should i get? and how much do they run?
Old Apr 6, 2006 | 12:57 PM
seacra's Avatar
check this sticky for a list of springs, coilovers and shocks: https://g35driver.com/forum/showthread.php?t=65190
one of the most popular shocks for our car is Tokico D-Spec shocks, and brand new they generally run between $550-600.
I'm also in the same situation as you guys. I want to drop my car not spending too much $, but I want to do it the safest way possible not ruining any suspension.
Old Apr 6, 2006 | 04:01 PM
aleok's Avatar
yea d-specs
but will we need aftermarket camber and toe arms? or just an alinement?
Old Apr 6, 2006 | 04:31 PM
seacra's Avatar
i'm not really an expert on suspension, i just observe some of the talks lately about suspension... it seems pretty much essential to get shocks if you plan on ordering springs. i believe that a decent amount of people also say it is essential to purchase camber arms because the tire life may wear down incredibly if you were to purchase springs and not update your cambers
Old Apr 7, 2006 | 12:26 AM
Gsedan35's Avatar
Most G35 based lowering springs are rather tame and not out of the range that oem shocks can control (except sedan non sport shocks). If the springs your looking at feature higher then oem rear spring rates by more then 10%, I do recommend the switch to aftermarket shocks. That recommendation has nothing to do with the theory concerning shock wear and everything to do with proper control and the owner ride and drive experience.
Old Apr 7, 2006 | 01:15 AM
Psycraft's Avatar
actually i didnt get the tanabe the drop was gonna be crazy it was way to much,it was 1.7 in the front and 1.3 in the back so i got the tein s tecs instead its a1.5 in the front and .9 in the back,i hope my shocks will hold up,and my car isnt all bouncy,if it is im gonna be super dissapointed.. =c/
Old Apr 7, 2006 | 08:55 AM
SFLG35's Avatar
FGC President
if you got the s techs for the g then it shouldnt be. they are actually softer than stock rates.
if you need the d specs let me know i can ge tthem for you at a pretty good price.
Old Apr 7, 2006 | 10:10 AM
Psycraft's Avatar
whats he diffrence between the 2? so the s tecs should be a real nice smooth ride..?
Old Apr 7, 2006 | 11:25 AM
Gsedan35's Avatar
Originally Posted by Psycraft
whats he diffrence between the 2? so the s tcs should be a real nice smooth ride..?
*Note: Where stiffer or softer then % specs are shown, they are vs any coupe delivered with oem 17's & 18's and any sedan with the sport suspension. Any coupe delivered with oem 19's has much stiffer oem rear springs in comparison (+27%)
Notice that the S-tech's use more front spring stiffness vs the Tanabe's.
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
Stiffer or softer then oem springs by F+ 5% R-22%*
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Stiffer or softer then oem springs by R+14% R-18%*
Tanabe NF210 Springs G35 COUPE progressive springs 1”/,6” drop on G35 coupe G35 sedan drop will be higher
Spring rates in LBS 297/336
Softer then oem springs by F-5% R-2%*
Tanabe DF210 G35 COUPE progressive springs 1.7”/1.3” drop on G35 coupe, G35 sedan drop will be higher
Spring rates in LBS 308/353
Stiffer or softer then oem springs by F-2% R+3%*
Tanabe NF210 G35 SEDAN progressive springs 1.6”/.9” drop on G35 sedan
Spring rates in LBS 297/269
Softer then oem springs by F-5% R-21%*
Tanabe DF210 G35 SEDAN progressive springs 1.7”/1.5” drop on G35 sedan
Spring rates in LBS 286/280
Softer then oem springs by F-9% R-18%*
Old Apr 7, 2006 | 09:45 PM
aleok's Avatar
^ but does the spring stiffness matter if you get d-spec shock? can't u just adjust them to a stiffer setting?
SFLG35: i might need a good deal on d-specs lmk how much. thanks
Old Apr 7, 2006 | 09:55 PM
SFLG35's Avatar
FGC President
hey i sent you a pm
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
